Nfusion
Username: Jamesta
Post Number: 14
Can someone help me. I recently got the new program installed for bell. My dish network is working okI am just not getting anything on bell. Which port settings do i scan the channels with. Thanks
Username: Rtap
FL
Post Number: 2314
if you are using a switch then 119 is port=1 - 110 port =2 91 is port =3
Username: Saqeeb9000
Post Number: 4054
menu installation , anteena setting, change ur dish to 82 or 91 degree west and change the diseqc as rtap told in above post until u get signals...
Username: Jamesta
Post Number: 15
Thanks. So should i erase everything including my dish network channels and then start from the beginning
Post Number: 4055
no.....
that won't erase any thing.
u will just get extra channels..
Username: Jamesta
Post Number: 16
huh. I believe that I did infact try that on 82 and 91 but I didn't get anything on bev
Username: Jamesta
Post Number: 17
And also keep in mind guys that I had to rescan all my channels . Dish network is working ok but bell isn't. That is why iam asking if I should put the settings to defaultand scan all the channels again
Username: Redwater71
Post Number: 90
James, if you're not aimed on BEV you're not gonna get anything, unless you're mtorized ... NO ?
Username: Jamesta
Post Number: 18
no I'm aimed at bev. It was working up until last week and then I had to get the new bin installed and I scanned the channels last night all i got was my dish network channels
Post Number: 4056
james use the latest bin.
latest bin is 1.48-3 and then scan all the bell channels..
Username: Jamesta
Post Number: 19
yeah i did get the latest bin but when i scanned last night it said no epg on the top and nothing was appearing so I am going to rescan but before i do that do I have to set everything to default
Post Number: 4059
james do a factory default and then reload the newest bin,and scan all the channels..
u need loader cable for this to do.
Post Number: 4060
james if u live in usa..
i am not sure if u know but bev introduced new nimq4 sat and u won't be able to get all the channels..
Username: Jamesta
Post Number: 20
I live in canada and I am presently not getting any channels. Should I scan again and if so should i set it to default before doing so.
Post Number: 4061
You will have to load U27 (found in files area under factory_kit) with cable & pc, followed by 148 Then set up user & system settings followed by setting up & scanning sats 1 at a time.
[link removed]
Post Number: 4062
james try scanning the channels first,
if u cannot get it then try this way..
Username: Mebn23
Toronto, Ontario Canada
Post Number: 13
I finally fixed my satelitte and got all my channels back but some channel are not working, it says bad or no signal.
SO for example, i have ytv west, family east and west, and telletoon east and west and they are all working. and ytv east is not working, it says bad or no signal. I think that is because i have 2 satelittles and my dad wanted a channel we couldn't get so he changed the position of one satelitte to a defferent area which is the other side of the house so what do i do to fix this problem?
Post Number: 4065
Mebn Selveswaran
Username: Mebn23
Toronto, Ontario
James Singer
Username: Jamesta
Post Number: 17
are u both same guy?
Post Number: 13
Username: Mebn23
Post Number: 14
No why?
and can u help me with my problem plz.
Post Number: 4066
mebn tell me the channels name and also sat name ,
i will check on nfusion..
