Silver Member Username: LroyPost Number: 422 Registered: Aug-06 | Is Nimiq 2 82w working. I am getting quality only on TP3 12252. whats going on.......... |
Silver Member Username: LroyPost Number: 423 Registered: Aug-06 | Correction on TP3 freq. 12253 |
Gold Member Username: PlymouthCanada Post Number: 4533 Registered: Jan-08 | Deleted all channels and blind scan |
Gold Member Username: KirankumarNO Bashing Post Number: 2986 Registered: Oct-07 | 82 w is going down a lot of people are loosing channels in other forums wait for new files |
Gold Member Username: PlymouthCanada Post Number: 4536 Registered: Jan-08 | African 82 is all up Only many channels change |
Bronze Member Username: JuanchoCANADA Xx Post Number: 100 Registered: Jun-08 | no is about files, nimiq4 coverage no is the same as nimiq2, ppl down in the far south of usa will have quality loss or complete loss of 82, , first ask where they are located |
Gold Member Username: Cartier1Post Number: 2099 Registered: Feb-07 | i have the same problem im located in ny |
Gold Member Username: PlymouthCanada Post Number: 4575 Registered: Jan-08 | Cartier try it https://www.ecoustics.com/electronics/forum/home-video/520025.html |
New member Username: Kasim123Canada Post Number: 2 Registered: Aug-08 | im trying to rescan echo 7 but i keep on getting desi channels i have checked my port it still does not show any english channels pls help |
Gold Member Username: PlymouthCanada Post Number: 4692 Registered: Jan-08 | irum kasim Check this solution for recover channels https://www.ecoustics.com/electronics/forum/home-video/520375.html |
New member Username: DewaltsucksPost Number: 4 Registered: Apr-08 | heared that Nimiq 2 (82) has changed to Nimiq 4 and narrowed footprint to canada so unless you live in canada or close to the border you won't get 82,you will also have to delete and re-scan to get all channels, |
Gold Member Username: PlymouthCanada Post Number: 4693 Registered: Jan-08 | I am not sure that is Nimiq 4 who cause the Tp lost, because some user can receive 82W in Mid center of USA without problem. On NFusion some user recovered all channels. |
Gold Member Username: Cartier1Post Number: 2114 Registered: Feb-07 | plymouth i have the tp for nimiq2 but no quality . dont know why still will all these confusion. even using an old bin the tp'\s are there but no quality. very strange humm. |
Gold Member Username: PlymouthCanada Post Number: 4710 Registered: Jan-08 | Cartier Try it exactly as write Do a factory default, go in keys menu and delete all provider for Bev and Dish with F3 on remote,load an older May bin, blind scan, load latest bin and now you will recover all missing channels. If it not work, probably you are right and spot beam not work in NY The thing is, i lost signal on many Tp exactly like you here in Canada and now all Ok. |
Silver Member Username: DimwittPost Number: 954 Registered: Aug-06 | C/P Plymouth Gold Member Username: Plymouth Canada Post Number: 4574 Registered: Jan-08 -Load any old bin files May 2008 -Blind scan all satellites for get new Tp Delete channels or satellite(Viewsat) Do settings on each satellites and autoscan it Do the Hokey Pokey load latest file and enjoy |
New member Username: Myguess21Post Number: 1 Registered: Oct-08 | I tried above solution, for some reason it didn't work for me. I may be doing something wrong here. I loaded 4 diff older files, I did auto scan. I also tried Factory bin then I load older file still not working. scarry part is after loading older file I did a scan and I am geeting only those 5 channels, which I had before the try. note that I have not loaded new file yet. I check the conf option it does shows the older file name. I believe that my Viewsat lite is not taking older version over the newer version. is that correct? no blind scan option in my program. what should I do next? or am I doing anything wrong here? |
Gold Member Username: PlymouthCanada Post Number: 4902 Registered: Jan-08 | myg My Ultra experiment many problem since last bin file. In 2 days, i lost 3 time all channels for nothing but it seems to be OK now with new factory file V0134 from Viewsatusa.com, i suggest to you load it and load latest file. If you want a total restore of your box, do it : Do a factory default Go in Keys menu and delete all Bev DN and Gc Provider with F3 on remote then load latest file rescan all satellites. Good luck |
Gold Member Username: PlymouthCanada Post Number: 4903 Registered: Jan-08 | myg My Ultra experiment many problem since last bin file. In 2 days, i lost 3 time all channels for nothing but it seems to be OK now with new factory file V0134(Ultra, get the bin for your receiver) from Viewsatusa.com, i suggest to you load it and load latest file. If you want a total restore of your box, do it : Do a factory default Go in Keys menu and delete all Bev DN and Gc Provider with F3 on remote , load fatory file then load latest file rescan all satellites. Good luck |
