Hi, Which plasma tv works best with viewsat xtreme. I know I wont be able to get hdtv programming on xtreme but if I want to buy a plasma tv to connect it to xtreme, which is the best one to buy and what size ?
There is very little difference these days between plasma and lcd. You can find cheaper models in both types. And more expensive too. Do some research. Decide what size is best for YOUR viewing area. As long as you are hooking up with best available cables to your tv from any device the picture will be good. I personally have a 42 inch Samsung (plasma) and I am very pleased with it.
