Bronze Member Username: Pj94zPost Number: 59 Registered: Nov-07 | I have a couple of FTA receivers that I use now...but I wanted to know if it's possible to connect them to my PC so I can watch TV on my PC ? Do I need additional equipment to make this happen? |
Gold Member Username: PlymouthCanada Post Number: 4703 Registered: Jan-08 | Pjx You can buy a PVR card like this one`: http://www.hauppauge.com/site/products/data_hvr1800.html |
Bronze Member Username: Pj94zPost Number: 60 Registered: Nov-07 | thx plymouth - so, if I buy that card.... I can just run a coax to the card from my FTA and watch any channel thats on my FTA ? Also, will this card let me watch HD channels thru my FTA ? ( i do not have hd fta) |
Bronze Member Username: Pj94zPost Number: 61 Registered: Nov-07 | btw...what do you think about the slingbox? It lets you watch your TV from the internet. |
Gold Member Username: PlymouthCanada Post Number: 4704 Registered: Jan-08 | Pjx """I can just run a coax to the card from my FTA and watch any channel thats on my FTA ?"". My PVR card can work if i hook the LNB cable, but i never try it on satellite signal. I think you must have a extra program. Surely another member can help you on it Your link on Slingbox not work. For me the computer is not made for listen the TV, i prefer a big screen. |
Silver Member Username: DimwittPost Number: 955 Registered: Aug-06 | Yes,run s-video and audio cables to the card - and all fta channels can be viewed thru the computer No , you cannot watch HD fta channels -- but with additional antenna you can watch loacl HD and other digital programming. PLYMUTT, Some Folk have big screen TV connected to their computer |
Gold Member Username: PlymouthCanada Post Number: 4751 Registered: Jan-08 | As big than 61" tweety |
Silver Member Username: DimwittPost Number: 956 Registered: Aug-06 | what difference does it make , sh!t for brains, you only LISTEN anyways. 'For me the computer is not made for listen the TV, i prefer a big screen.' |
Gold Member Username: PlymouthCanada Post Number: 4772 Registered: Jan-08 | Pjx A good PVR card can be hooked directly from LNB and from your receiver with, S-Video, and simple Composite Video RCA |
Silver Member Username: DimwittPost Number: 965 Registered: Aug-06 | stfu |
