FTA to computer
Username: Superslammy
Post Number: 71
Can someone give me some advice on connecting a Pansat 250SM to a computer? I would simply like to send the video to a computer. I know this means the same channel must be viewed on both devices. That's ok. Would I use the IF out on the Pansat and connect it to either my video card or tv tuner card?
Thanks
Username: Dimwitt
Post Number: 873
IF OUT needs to be connected to another receiver , i connect cw600s to computer with s-video cable to tv tuner card
Post Number: 72
Thanks Harry. Do you use your tuner card software to view it? What channel or input device do you select?
Thx.
Username: Dimwitt
Post Number: 874
I use WinTV and select the s-video input (located in channel menu).
