Need Help on 82
Username: Kanishk
Post Number: 14
I have dish 500, originally pointed to 110 & 119. Because of trees in the line of sight, lost signals for d**h. Trying to point 82, 91 B*V. Get good strength and quality on 91, but can't able to catch 82. Both lnbs when connected independantly to receiver will show only 91, but not 82. Location North East/NY area. Any easy tricks to get 82? Any help will be appreciated.
Username: Kanishk
Post Number: 15
Receiver is Captiveworks 600s Regular
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3584
kanishk
use these site for aimed all sats
http://www.dishpointer.com/
on dual or more LNBs on same dish, skew is very important.
Username: Kanishk
Post Number: 16
Thanks. I will try tomorrow, and let you know how did it go. Thanks for the info.
Username: Nydas
Post Number: 11501
kanishk: The common problem in trying to swing a dish pointing to 110/119 to point to 82/91 is that you stop at 91/100 - that might be your problem
Username: Fattay
Post Number: 54
Your skew will (look) flat on 91-82,but is as plymouth says, very important! I had no problem with 91,,and "skew" was the problem obtaining 82.
