No Signal on Sonicview 360 Premier. Need help
Username: Coolsatfv
Post Number: 46
lost my patient with CS4K and 5K. I just bought a new sonicview 360P. Hooked up to the same cable which I've been use with C*sat before to receive 119w without any problem.
Now, i'm trying with the sonicview but i got "no signal" on all of 119 channels. The box is running on the lastest "black-out" version 1.42 firmware.
Please advice. Thx,
Username: Kriskros
Post Number: 111
reallign yur antenna. after i switched from neosat to viewsat, i needed to reallign. viewsat was very sensitive to signal strenght. neosat used to pick up DN500 signal with rabitears...
Username: Coolsatfv
Post Number: 47
Thanks for your help, Kris. But the S and Q signals are received pretty strong. Im going to reload the factory firmware and the new bin again.
