Hello. I have two DISH pro satellites with 1 single and 1 dual LNB. However, in the antenna settings under DISEQ I can't see a port for 61.5. Please help with settings. I need to get indian channels. I have ViewSAT VS PRO
First it would be best if you have a compass or sat finder meter. Then go to xxx.dishpointer.com (replace xxx with www) to get your coordinates. From satellite menu select 61.5 in your Antenna Setup menu. Here are the settings. LNB - ON LNB Type - Standard LNB Freq. - 11250 TP Freq. - 12326 If you are not using a switch and this is a direct hookup from LNB to your reciever, then make certain that all switches are set to OFF or None. If you are using a switch then adjust your settings accordingly in the menu. Good luck.
I can get Echo 3 real good,using 8.5ft B.U.D. & an old directv lnbf with a lnbf clamp to hold it on my B.U.D. using a Pansat 2700a reciever,my problem is I can't get echo 1&2 & I live in deep south Texas,should I be able to get Echo 1&2? or Am I mistaken? Your help would be greatly appreciated!Thanks!
