Help with viewsat ultra set up
Username: Candy1
Post Number: 32
I am trying to get chanals to come in on a new view ultra but i can't any picture
i can get radio music i did all the autoscan and a blind scan than it ask if i wanted to save but the remote would not work any more.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2774
Which bin you loaded in your Ultra?
Load this one: PFTAUSW-080627UL.zip
Take it there: [link removed]
Username: Plymouth
Post Number: 2775
Your remote dont work?
Do this:
In your package box with receiver is furnish a cable RS-232 you must download factory bin with the cable from your computer .
Go to: <[link removed]>
download this 2 files:
PVR/Ultra Loader v1.1 - Firmware Updater ( Serial)you install this one on computer
VS2000 ULTRA Factory Bin File - V132
for download with the loader in your receiver
close rear switch on receiver
open program take file v131
clic to download in receiver and a second after
switch on
the transfert take 5-10 mins
you must see 0000
download the last bin with USB
Good luck
Username: Plymouth
Post Number: 2776
You needed to load Sat Info too: General Satellite Info File (compatible with Platinum, Lite, Xtreme, Ultra only !)
On same site
[link removed]
