SWITCH HELP
Username: Jilydon
Montreal, Quebec Canada
Post Number: 13
hi i have 3 dish with dual lnb each one for bev one for 61.5 and one for 119-110 i was wondering how can i have this 4 sat working on my 3 receivers(1view ultra and 2 flu)which diseq should i use and would it work with sw64??? please let me know as i didn`t buy my switchs yet many thanks. I READ THAT SOME SWITCHES THEY DON`T WORK IF YOU HAVE BEV AND 61.5 ON THE SAME MULTIPLE SWITCH IS THAT TRUE PLEASE LET ME KNOW WHAT IS BEST WAY TO DO IT MANY THANKS....
Username: Tapeman
New York City in-HD, NY
Post Number: 2883
- Zinewell 6x8 can do the job no external power required
- SW-64 is just good for 3 sats & 4 receivers but it requires seperate external power source so annoying if yo don't have a near by P/S
- DP34 is OK however it will need a 1000mA current 20Watt receivers only DN go that high none of the FTA receivers can do
Many people attach an old unused DN receiver to generate that 1-Amp Current
FTA is one thing pay service is another
But I would pick the 6x8 switch as a better choice
Username: Tapeman
Post Number: 2886
This is the easist way for 2 satellites to 4 receivers
Switch under $20 on e-bay
Yo can use 3 satellites like this
Sat-1 will be available on all receivers
Vertical polarity only from Sat-2
Horizontal polarity from Sat-3
If yor more advanced installer yo can add 2 more 22k switch and combine the other 2 polarities
This is 5 satellites on one receiver
This is 8 satellites on one receivers
Username: Master_lee
Post Number: 93
This is 30 satellites on one receivers
Username: Mucho
Post Number: 345
King Tapeman you say that Vertical polarity only from Sat-2
The drawing of the Zinwell 4x4 Multi Switch shows Sat-2 connected to the 18 volt port. 18 volts is for horizontal polarity, and 13 volts for vertical polarity. Please correct your post.
}Upload
Username: Kirankumar
NO Bashing
Post Number: 2854
get a dp34 switch
3 in 4 out
Username: Tapeman
Post Number: 2887
African DP34 won't work without a 1000mA power source (1Amp)
He must attach a seperate receiver to generate enough current
Like I said above Zinewell 6x8 will be yor best option plug and play type of switch
When yo share multiple satellites on a switch designed for 2 satellites one polarity will over-ride the other
Usually is 18V parallel with 13v will produce 18V so as yo change thru the channels polarity struggle will take place as all recivers on at the same time
The wiring I got here will improve sharing but maping the 22k on all 4 receivers will be a challenge for any one with no electroncs background
So save yorself a headache or try to understand this maping:
Now this is just an idea
Improvement can be made cuz this is an improvised sketch that I just came up with for non-motorized fixed satellites
Username: Afrimpeja
Forest hills, Ny Usa
Post Number: 67
Hello i try to conect to recivers one dish so i bought a dp34 switch after i cont to it i lost most off chanels and in some i have bad or no signal can someone explain me why is this do i need anoher switch ?
Username: Tapeman
Post Number: 2892
It sounds like a bin issue not a switch
Username: Afrimpeja
Post Number: 68
but King Bin is the same tha i had the chanlas wher working but whn i conect dp34 switch its not the same as without the switch i so your post up somthong abput dp34 not good bether the ZINWELL so u think i should order this switch or dp34 will work? i have a Magnum and a Pansat 2700
Username: Tapeman
Post Number: 2894
Yor problem requires factory default and rescan channels
This has nothing to do with either type of switch
The right thing to do is create a new thread list yor hardware and I will help yo
