118.5/119
Username: Cdeepak
Post Number: 32
I know we can get 118+119 on same
dish with special LNB.
BUT if I ONLY want to get 118....do I still need to get that special LNB? or any standard LNB will work?
Username: Nydas
Post Number: 10919
You need a LNB designed to have a LNB freq of 10750 or less. The "standard" LNBs you are referring to are designed to work on 11250.
You need a specially designed circular LNB. A CB2008A is only about $20-25. The bigger cost is in having to buy and mount a 33-36" Dish, and getting a special bracket to house this LNB.
Username: Way2smart
Www.Desifta.com
Post Number: 1629
you can use a 18X24 dish to get 118....and you neeed the lnd to make it work
im using a Ariza Circular Dual Lnd Model:CL832-30
