Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1850 Registered: Jan-08 | Puff 263: |
Bronze Member Username: RagsPost Number: 17 Registered: Oct-06 | Anyone try it out yet? Has fwank got anything going yet? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1852 Registered: Jan-08 | Test and work fine |
Gold Member Username: Dakangofkrunk16Boca Raton, Florida Post Number: 1548 Registered: May-07 | wtf is a Puff 263... Ive been wit FTA for 2 years neva heard of it |
Silver Member Username: Jwl1Post Number: 278 Registered: May-06 | 263 Puff also available at Ftatalk (.com) |
Bronze Member Username: BluegillbillPost Number: 60 Registered: Sep-06 | puff bin 263 no good |
Gold Member Username: Dude123Post Number: 2172 Registered: Jul-06 | tested and working good...available at |
Silver Member Username: LololPost Number: 288 Registered: Sep-06 | Kangology 101 Well if you have been in the FTA hobby and you dont know what puff is. I would suggest you read a little more because it seems like you do not have much experience with your own hobby. |
New member Username: Arthur22Post Number: 1 Registered: Feb-08 | thanks Plymouth, works good! |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1853 Registered: Jan-08 | Your welcome |
Gold Member Username: Dakangofkrunk16Boca Raton, Florida Post Number: 1549 Registered: May-07 | Well i have neva used a puff anyhting... So why don't you enlighten me what exactly it is... |
Silver Member Username: GregrafPost Number: 187 Registered: Dec-07 | I always puff one before i start |
Silver Member Username: Ather_da_donMississauaga, Ontario Canada Post Number: 469 Registered: Oct-07 | Allso out at |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1854 Registered: Jan-08 | Kangology 101 Read this: https://www.ecoustics.com/electronics/forum/home-video/459146.html |
Bronze Member Username: BluegillbillPost Number: 61 Registered: Sep-06 | Plymouth I reported early that puff 263 was no good that was wrong after off on back for 4 hours working fine thanks plymouth you are good man |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1855 Registered: Jan-08 | bluegillbilll I post it a 12:32 and you say the bin is not good at 2:18, what is the problem, you are the only one who report it. Personnaly i dont try it. This bin come from Ecoustic: https://www.ecoustics.com/electronics/forum/home-video/399884.html Nikk Mty Gold Member Username: Nikk Post Number: 2001 Registered: Oct-07 Les dejo la liga para el bin PUFF... Recien lo estoy probando, al parecer funciona bien, se tarda un poco en la imagen al cambiar de canal... Se los dejo para el que quiera probarlo...esta en etapa de prueba... Nikk_Mty_Jvvh_Team_PUFF_263 |
Bronze Member Username: BluegillbillPost Number: 62 Registered: Sep-06 | PLYMOUTH at frist I had freezing & 110 would not come in after off on the back switch everything is fine thanks |
Bronze Member Username: BluegillbillPost Number: 63 Registered: Sep-06 | PLYMOUTH after switch off for 4 hours everything is fine thanks very much |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1856 Registered: Jan-08 | I'm happy for you You are Welcome |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1857 Registered: Jan-08 | Thats probably because you empty the RAM memory (hard reboot)and Backup memory(Clock, password and User setings)on most that take 1 hour to 3 hours.(condenser high in Mfd) If bad data is store in Backup memory you can have freeze and sat setup altered. This space memory is small on receiver. Good TV |
Bronze Member Username: HabooshPost Number: 16 Registered: Oct-07 | iam still using b_75 file is there any file for it now i have been a way ?? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1860 Registered: Jan-08 | damdoom On which receiver |
Bronze Member Username: HabooshPost Number: 17 Registered: Oct-07 | convertor fortec to pansat 2700 |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1862 Registered: Jan-08 | damdoom Start a new thread and ask it https://www.ecoustics.com/electronics/forum/home-video/35.html Nalin can help you I'm not familiar with that Sorry |
Platinum Member Username: NydasPost Number: 10184 Registered: Jun-06 | Everything for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 or PUFF. LZMA version not available. http://public.box.net/2500_full_kit All downloaded zipped files should be unzipped into a separate directory named appropriately. |
Bronze Member Username: Snuffles07Post Number: 86 Registered: Jan-08 | Nalin. Is there a certain box where all you have is the 263 PUFF bin? I don't wanna download a box from your site and have 20 different things that I don't need downloaded on my computer. |
Platinum Member Username: NydasPost Number: 10186 Registered: Jun-06 | 263_b75_ALL_BINs.zip has two b75 BINs 263_PUFF_ALL_BINs.zip has two PUFF BINs |
Bronze Member Username: Snuffles07Post Number: 87 Registered: Jan-08 | Alright thanks Nalin, very helpfull like always. Truth is, if it weren't for you, I wouldn't be watching tv so thanks again. |
Silver Member Username: SccrskillsPost Number: 114 Registered: Dec-06 | guys i tried the 263 puff scanned all the sats but when i try to watch the tv it just says scrambled i tried rebooting from back but still noting. any help thnks. |
Platinum Member Username: NydasPost Number: 10190 Registered: Jun-06 | There are at least 5 PUFF BINs available. Change to Lothario or Saif BIN. Remember, you may have to scan the sat(s), if you do not see any channels. |
Silver Member Username: ShadycovePost Number: 173 Registered: Sep-06 | sccrskills....set default key,, |
Bronze Member Username: GupulambaBrampton, Ontario Canada Post Number: 44 Registered: Oct-07 | hi can someone tell me where can i get the b75_m 64k bootfile from please thanks |
Platinum Member Username: NydasPost Number: 10198 Registered: Jun-06 | See my post 4-5 posts above. it is in the b75 section of the full_kit |
Gold Member Username: NikkPost Number: 2002 Registered: Oct-07 | guys i tried the 263 puff scanned all the sats but when i try to watch the tv it just says scrambled i tried rebooting from back but still noting. any help thnks You have to press 8282 from the remote, then select the "Set Default Keys" option, then exit and go to channel 200 and let it autoroll...} |
Silver Member Username: LetmeonPost Number: 220 Registered: Mar-06 | bin 263 Fwank7 version working fine on Pantec Ultra MX converted to PUFF. |
Platinum Member Username: NydasPost Number: 10204 Registered: Jun-06 | Non-PUFF 263_p122654_b-75.bin working totally flawlessly. No freezing, all channels showing as expected. |
