VS Ultra help again
Username: Abeyambu
Post Number: 13
decided to run with just 119. now i am getting very few channels. most are on a "searching" pattern. when plug the 110 coax into the diseqc it works fine. have reloaded bin file. still same!!!!!. quite FRUSTRATING
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1734
abe
with RG-6 unhook
Do a hard reboot
do a factory default
do a hard reboot
load last bin
do a hard reboot
hook RG-6
setup each satellite and autoscan
Good luck
Username: Plymouth
Post Number: 1735
abe
If it does not work reply, we can try heavy duty reset on your box.
Thanks
Username: Hawaiian_time
Kanaka freak...
Post Number: 1891
Try getting your bin from another site and load that one.
Username: Plymouth
Post Number: 1739
You can try this main pgr:
http://www.box.net/shared/ytdcaz604o
and this bin:
http://www.box.net/shared/dz5d6vuo0g
Username: Kirankumar
NO Bashing
Post Number: 2467
this has nothing to do with the bin,it is good.
the problem lies in your cable/connectors/switch/antenna settings or dish alignment.
Username: Abeyambu
Post Number: 14
afro : i have a pansat 2700 on same hook & set up and its OK. I will try lateron plym. suggestion. i appreciative of your answers
NO Bashing
Post Number: 2473
your pansat 2700 might be ok,but remember that the vs ultra is very sensitive to bad cables and connectors,
been there done that,i had to change cables to get vs ulta going where as all my other boxes were running great..just my 2 cents
Username: Plymouth
Post Number: 1743
African
I have a viewsat and some of my friends have it and this box work fine.
I dont know why you say that.
Buy this box and test it before saying anything.
You are a good helper
Please do not confused poeple.
Thanks
Username: Abeyambu
Post Number: 15
my ultra now got freezed.followed instructions loading mainpg,pgm thru USB. i only get a "P" on the fron 4 digit pannel
Username: Plymouth
Post Number: 1748
Abe
Try to load bin with USB now
Note: international channel have freeze problem
Username: Abeyambu
Post Number: 16
ply & afro : i changed to port 3. i also changet an RG6 from diseq to lnb. did a fact. dafault. loaded factory bin , loaded latest bin 080410. now its fine. however: exchanged with pansat2700. it shows a lesser signal on SOME TP like 12515 ( 434 nesn ) wich is a must for me.
Username: Plymouth
Post Number: 1809
Good new Abe
The signal and quality can varied on different receivers.
Note i have now a reserve on factory bin V-132, i think this bin corrupt deliberately Port1.
Good TV
