Username: Chilli Post Number: 85 Registered: Jan-07
Tuesday, April 15, 2008 - 00:13 GMT put in the latest bin but some of the channels i get a no signal screen.so i tried to rescan the channels and the only ones that went in were the ones that got a signal.Doubles of all these channels.Some help with getting all the channels to scan would be great.
Username: Plymouth Quebec city,
Quebec
Post Number: 1751 Registered: Jan-08
Tuesday, April 15, 2008 - 02:42 GMT babies12 Do a hard reboot(switch on back panel) Write setup on each sat Delete sat an rescan sat
Username: Chilli Post Number: 86 Registered: Jan-07
Tuesday, April 15, 2008 - 03:02 GMT i did a hard reboot and i also deleted all the channels and rescaned
Quebec
Post Number: 1753 Registered: Jan-08
Tuesday, April 15, 2008 - 03:11 GMT That work or not?
Username: Chilli Post Number: 87 Registered: Jan-07
Tuesday, April 15, 2008 - 03:19 GMT no still won't scan in all b3v channels.Even did a factory reset on still only scans half the channels
Quebec
Post Number: 1757 Registered: Jan-08
Tuesday, April 15, 2008 - 03:29 GMT babies12 You can try blind scan or power scan
Quebec
Post Number: 1758 Registered: Jan-08
Tuesday, April 15, 2008 - 03:34 GMT One thing your channel are all vertical or horizontal, or on both? If your cable have bad connection you can lost half channels, because with low voltage on LNB you can loose vertical signal
Quebec
Post Number: 1759 Registered: Jan-08
Tuesday, April 15, 2008 - 03:39 GMT You can try to replaced cable with the other LNB. The switch can do that too I replace a switch who lost only one TP freq. Good luck
Username: Chilli Post Number: 89 Registered: Jan-07
Tuesday, April 15, 2008 - 03:46 GMT loose cable in the back of the receiver thanks for your help
Quebec
Post Number: 1762 Registered: Jan-08
Tuesday, April 15, 2008 - 03:50 GMT babies12 Good news
