Captain 7100 usb has iks :-) woohoo
Username: Oniea
Post Number: 15
apparently with the newest bin we are going iks
Username: Saqeeb9000
Post Number: 3109
built in iks . thats innovative..
does this rec have ethernet port?
Username: Oniea
Post Number: 16
no runs through the serial port
Post Number: 3110
then i don't think iks will last longer.
like nfusion u need constant internet connection
Username: Fattay
Post Number: 49
So,,Cap-8000 can iks also? Will 8000 pick up dic hd and bev hd? Or do your have to fork out the $ for 8spk? Thanks
Username: Lklives
Post Number: 15322
Dongle (IKS) solution for all Captain models
Captain is now the FIRST FTA STB to have a STABLE Dongle (IKS)
solution and the first to have a High Definition receiver working through IKS
It is with great pleasure we announce to you that we now have a working Dongle (IKS) solution for all Captain models.
Currently the Dongle is working stable on about 220 channels which include all PPV and Adult on both providers.
Also, there is one HD channel working on the Captain 8000HD to show that the solution is HD compatible.
The rest of the channels will be added shortly!
Captain is now the FIRST HD receiver to work through IKS
The Dongle, as you can see in the attached pic, is portable and connects by serial port.
It also requires power. (short serial cable and power cable included). Again, Captain has come through for you!
You can now expect many surprises to come from Captain in terms of new models.
We are still working to make our Mpeg4 HD unit the lowest priced and most dependable in the market.
A LIMITED QUANTITY FOR OF CAPTAIN-COMPATIBLE DONGLES IS NOW AVAILABLE FOR SALE at [link removed]
Thank you all for your continued support
Team Captain
Welcome To CompleteFTA
* * * Latest updated news April 9 2008 7:30PM EST * * *
TEAM CAPTAIN JUST POSTED NEW IKS SOLUTION FIX
NEWS FROM TEAM CAPTAIN
We Are Working On Standalone Solution And Should Have Something ready Soon
Check The Forums For More Details
Dongle IKS FIX ONLY
Captain8000HD_IKS ..USB ready
Captain7100USB_IKS..USB ready
Captain7000_IKS...must use cable
here;s how ya load..
We are proud to announce our first beta release for iks dongle
We will be adding more channels and more options as we further along out of beta stages
DONGLE IKS ONLY
RLS NOTES :
IMPORTANT IMPORTANT
1st ) do a factory default
2nd ) Load factory firmware
3rd ) unzip the attached file load it via Null Modem Cable
4th ) after upgrade has finished do a hard reboot again and attach cat5 Cable to the dongle and Null modem Cable to dongle and the receiver
5th ) go into Menu System options and Network Setup
6th ) Enable Network and exit to save System will now Hard Reboot Again
(This Reboot Will Detect your network Settings)
7th ) Setup your sats and Scan as per your setup
8th ) enjoy your IKS
We thank you for your support and hope you Enjoy IKS
Team Captain
Username: Fattay
Post Number: 50
Thanks for the information LK, great job. I found bits and pieces of info from goog, mostly other threads in diff forums, but nothing solid like this. Thanks again.
Username: Krishn
Post Number: 111
Currently no 8PSK without adapter
