Viewsat Ultra Still Not Working After Blind Scan
Username: Crazydoo67
I followed Plymouth's instructions from yesterday re: All viewsat box
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
no need to delete keys
switch off 10 secs on back panel
and load last bin for your box
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Resolve problem with lost channel , autoroll, freeze and search signal
Thats erase bad data in the box
For box who lost channel and sat setup
ENJOY TV
It didn'twork..I"m still unable 2 get any channels after that darn blindscan..and I have the new file for Mar. 28/07..this has never happened.. can anyone with any expertise help..I need BEV and the foreign language dishnet 2 work..thanks
Username: Nydas
Post Number: 9617
If you have both DN and BEV, you have to scan BEV first and then DN.
Username: Saqeeb9000
Post Number: 2981
tell us channels name .. u can do a mannual (advance) scan where u can add tp/freq...
Nalin,
Do I have to do an autoscan after the blindscan?
Nalin...it keeps automatically blindscanning echostar 3 before it scans Nimiq 1,3 (bev)...
Username: Nydas
Post Number: 9632
Your antenna settings must overlap.
I am signing off now.
Post all your antenna settings and your physical set up and tomorrow I might be able to look at it.
Anyway, somebody else might see the problem and be able to help.
Username: Sidxx
hi where do i get viewsat ext fix pls
Post Number: 2983
[link removed]
Username: Luser
Post Number: 167
Check antenna settings
lnb type=your type
freq=11250
22hz=off
lnb=on
If you have switches for multi sats or 2 lnbs in one casing you will need diseq or sw ports to corispond.
Most important is to get good quality of the 2 signal bars and that the name of the sat your receiving signal from is displayed in the upper right and should match that of the one on top settings list. The quality will increase as settings change to the correct ones. Autoscan or channel scan do not blind scan do not mess with keys. Make sure autoroll is on auto tp is off. Most everything being told is BS from retards or for other old receivers and doesnt apply to viewsat. Its always simple like connect cable.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1359
Read it:
https://www.ecoustics.com/electronics/forum/home-video/466791.html
