Pansat 2500a *** dead ***
Username: Dnvrguy
Post Number: 27
hi all, i probably killed my receiver pansat 2500a, coz the display keeps showing P U F F forever so is there anyway to convert back to original pansat 2500a without jtag like a factory bin or something . i will really appreciate it. thnx all
Username: Nydas
Post Number: 9432
It is not dead.
You now need to load the latest PUFF BIN.
There is a huge set of instructions and files if you want to be a bit patient and read.
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included. Either b75 boot or PUFF boot or PUFF_LZMA boot and matching BINs
http://public.box.net/2500_full_kit
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Dnvrguy
Post Number: 28
thnx Nalin for ur help, i did all the instructions says , when it does not work i start downloading anything could help , like boot60 nad so , i know even now what file it got, it says just P U F F keeps running from the left to the right plz what can i do ? thnx
Username: Nydas
Post Number: 9434
LOOK AT THIS:
[link removed]
