Gold Member Username: AsharfiPost Number: 1894 Registered: Aug-06 | Hello, Here's the latest bin for the converted FLU/2500 - PUFF receivers by Chancysand. This bins fixes BEV freezing and all DN & BEV are UP! Download from |
Gold Member Username: NydasPost Number: 9166 Registered: Jun-06 | and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 or PUFF http://public.box.net/2500_full_kit You must select whether you want to have the old b75 files or the new PUFF files. If you have b75 boot, you must convert to PUFF boot to use PUFF BINs. Read the instructions properly in the section you have chosen. WITHOUT READING INSTRUCTIONS. |
Bronze Member Username: Micky1982Haway, Ct Usa Post Number: 21 Registered: Jan-08 | nalyn , u make it so complicated i open yor files and not understanding anything no, im havinh clone pansat (conveted from FLU) SO what i dd to do, be specific and expain her do not tell me, rad the complicated intruction |
Gold Member Username: NydasPost Number: 9175 Registered: Jun-06 | Those are the best instructions and full kit I have found - so I recommend them. It is a process which might lead you into a dead receiver unless you carefully read and understand what is involved. If you are unsure, try and get somebody computer savvy to join you in making the effort, but please do NOT do anything without understanding. |
Bronze Member Username: Micky1982Haway, Ct Usa Post Number: 24 Registered: Jan-08 | can u answer me her? | |
Gold Member Username: NydasPost Number: 9179 Registered: Jun-06 | Unless you are willing to download the files and read the instructions it would be futile and prone to getting a dead box. I suggest you have a computer savvy friend with you who can guide you into doing the right thing. | |
Bronze Member Username: Micky1982Haway, Ct Usa Post Number: 27 Registered: Jan-08 | funy answer god kill u nalyn in the the hell |
Gold Member Username: NydasPost Number: 9185 Registered: Jun-06 | Three threads - You are joker. | |
Bronze Member Username: Micky1982Haway, Ct Usa Post Number: 34 Registered: Jan-08 | IM NOT JOKER I NEED THE TRUE ANSWERR U KEEP ANSWER ME BY 1 WORD |
Bronze Member Username: Micky1982Haway, Ct Usa Post Number: 35 Registered: Jan-08 | LISTEN I DONT HAVE TIME TO PLAY ANSWER ME MR NALYN IN SPECIFIC WHAT TO DO I HAD TOLD U, WHAT I SAW IN MENUE SO WHAT NOW THE NEXT STEP |
Bronze Member Username: Luv2meetPost Number: 51 Registered: Dec-07 | Here is an easy instruction I found posted by Saboo at dssworld: FLU / Pansat 2500 to PUFF Conversion You will need the following things before you start the conversion: - RS 232 female-female STRAIGHT cable with 9 pins on both sides - FLU OR Pansat 2500 Remote - 2700 - 2500 Loader (included) - Boot File v6.0 (included) - Blacklist Loader 1.4.0.0 (included) - Jvvh_Fortec-Pansat_CanAm_(PUFF)_253_(640K) Bin (included) --------------------------------------------------------------------- Instructions / Procedure - Turn OFF your receiver from the back switch. - Connect your receiver to your computer using the RS 232 female-female STRAIGHT cable with 9 pins on both sides. - Turn ON your receiver from the back switch and let it reboot. - After your receiver fully reboots, you'll see ON on the front panel of your receiver. - Leave the receiver ON and open the 2700 - 2500 Loader. - Click on the Bin File button on the loader's window and select Boot60 bin. - Please select your correct COM serial port and choose the Boot File Only option. - Click the Download button and wait for the bin to download. - After it's done, you'll see knight rider lights on the front panel of your receiver (- - - -). - Leave your receiver ON. - Close the 2700 - 2500 loader's window. - Open the Blacklist Updater (Blacklist Loader 1.4.0.0) - Click on the Select Bin button on the loader's screen and select the Jvvh_Fortec-Pansat_CanAm_(PUFF)_253_(640K) bin. - Please select your correct COM Settings and choose the BIN option which is right beside the BOOT option. - Click the Write Bin button and wait for the bin to download. - After it's done, your receiver will reboot automatically and it'll turn ON after 1-2 minutes. - Your receiver has been converted to PUFF. - Now, just simply load the latest PUFF bin by JVVH and you're good to go. Note: From now on, you MUST load bins that are named PUFF. After you load any new bin, please do the following: - go to MENU - click on Parental Control - click on Second Pin and enter 0000 - click on Set Default Key - Now, wait for the keys to autoroll and then you can watch TV. |
Bronze Member Username: Luv2meetPost Number: 52 Registered: Dec-07 | Sorry, couldn't upload the files but they are quite similar to what Nalin has provided but if you prefer to get from another source here you: registration is required cheers. |
Bronze Member Username: Micky1982Haway, Ct Usa Post Number: 38 Registered: Jan-08 | NALYN IS VERY COMPLICATED PERSON, THOSE INSTRUCTION ARE CLEAR THAN HIM | |
Silver Member Username: Koko_wawaPost Number: 284 Registered: Aug-07 | I followed Nalin instructions several days ago and I successfylly converted my 2500 Flu to PUFF I only had problems with rebooting and he suggested to use bin 254 by lothario instead of JVVh bin. Since then my 3 and 1/2 years receiver works like a brand new one. T | |
Bronze Member Username: Luv2meetPost Number: 53 Registered: Dec-07 | We can't but to say many thanks to Nalin for all his contributions on this BB | |
Gold Member Username: NydasPost Number: 9189 Registered: Jun-06 | There are, I think 3 or 4 PUFF BINs out for version 256. There are 2 b75 BINs out for the 256. Both BOOTs have a Lothario version. | |
Silver Member Username: Bill038Post Number: 555 Registered: Sep-06 | Nalin Nyda Gold Member Username: Nydas Post Number: 9144 Registered: Jun-06 Posted on Wednesday, March 12, 2008 - 07:06 pm: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here.. |
Gold Member Username: NydasPost Number: 9203 Registered: Jun-06 | Bill Vickers: You are highjacking this thread. Bill Vickers wants to know: Posted by Bill Vickers on Saturday, March 15, 2008 - 11:05 am: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. -------------------------------------------------------------------------------- If anybody has information please DO NOT provide it to him. He is part of a mob wanting to hit at LK. |
Platinum Member Username: LklivesPost Number: 14661 Registered: Jan-06 | Nalin Nyda Gold Member Username: Nydas Post Number: 9144 Registered: Jun-06 Posted on Wednesday, March 12, 2008 - 07:06 pm: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here.. |
Gold Member Username: NydasPost Number: 9214 Registered: Jun-06 |
Silver Member Username: Bill038Post Number: 559 Registered: Sep-06 | Nalin Nyda Gold Member Username: Nydas Post Number: 9144 Registered: Jun-06 Posted on Wednesday, March 12, 2008 - 07:06 pm: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here.. |
Gold Member Username: NydasPost Number: 9221 Registered: Jun-06 | DO NOT highjack. These instructions are for Pansat2500/FLU whether converted to b75 boot or not DO NOT USE ON GENUINE PANSAT 2700 OR REAL CLONE PANSAT 2700 Preparation 1. Connect receiver to computer using a straight RS232 cable 2. Turn on racier and let it come to rest at ON or the last channel number 3. Save your current channel list. 4. If your channel list is more than 6 months old, skip all the above. 5. KEEP RECEIVER ON. Loading Boot60 '" only for new conversion to PUFF 6. Start 2700 to 2500 conversion software by Chancysand. 7. Select Boot in the Loader software. 8. Select Boot60 from the distributed software. 9. With the receiver ON, click on Write. 10. Wait for write to complete. 11. KEEP RECEIVER ON. 12. You will see horizontal night riders. DO NOT PANIC. 13. Close the 2700 to 2500 conversion loader and Loading Boot/BIN PUFF-Only for new conversion to PUFF '" must use the 640K PUFF BOOT/BIN combo. 14. Start the BL 1.4 updater. 15. Select Chancy's or jvvh 253 boot/Bin 640K file. The file name must have the word PUFF in it. 16. With receiver ON, Select BIN in the Loader and start write BIN. 17. When it has loaded it will say BURN on the loader software . 18. DO NOT SWITCH OFF. 19. When BURN is completed, your receiver will reboot and sat P-U-F-F 20. Leave it on. 21. Wait till it stops PUFFing and says ON. 22. Now switch it off. Loading latest PUFF BIN. This is the part to be repeated in future with newer PUFF BINs. You will always use PUFF BINs clearly labeled PUFF 23. In the BL update 1.4, select the latest 256 PUFF BIN and select BIN in the loader. Keep right hand on mouse ready to write. 24. Turn on receiver at the back using left hand and as soon as you see P (of PUFF) scrolling, click on Write with right hand. 25. Again wait for BURN to take place and then the receiver will reboot, go through the P-U-F-F cycle and rest with ON showing. Loading Channels. 26. Now install the channels using channel master. 27. Disconnect from receiver and connect to your TV. Do user set up and attend to autoroll. 28. First thing '" do a user setup including date.time, time zone and turn closed caption off. Blind Scan if Channel list old or not available. 29. If your channel list is good, you may skip a blind scan, otherwise do a Blind scan of your sat '" just one sat first. 30. If keys do not autoroll, go into parental control (CAS menu) and click on 'Set Default key and wait for autoroll to load the keys. It takes about 2-3 minutes. 31. You must do switch Off and On at the back in between if things are not happening as they should.. |
Silver Member Username: Bill038Post Number: 560 Registered: Sep-06 | Nalin Nyda Gold Member Username: Nydas Post Number: 9144 Registered: Jun-06 Posted on Wednesday, March 12, 2008 - 07:06 pm: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here.. |
Gold Member Username: NydasPost Number: 9224 Registered: Jun-06 | Bill Vickers: Ypou have been chasing me all day. The person to ask is LK - She is the one who has given evidence in courts. LK's actions in the Courts of America are hers - not mine. If she wishes to divulge information as she have done in the past - that is her prerogative. As far as I am concerned, anything she did on orders of a legally constituted Court or Tribunal is part of a citizen's duty and she cannot be persecuted or lynched for it. Citizen's duty to the state also applies to laying information to the police about any fraud such as the ftaprosupport fraud she reported and it is her duty to report or confess as the case may be. People like you are not wanted or needed here, as evidenced by the posts here. |
Silver Member Username: Bill038Post Number: 562 Registered: Sep-06 | Nalin Nyda Gold Member Username: Nydas Post Number: 9144 Registered: Jun-06 Posted on Wednesday, March 12, 2008 - 07:06 pm: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here.. |
Gold Member Username: NydasPost Number: 9230 Registered: Jun-06 | LK's actions in the Courts of America are hers - not mine. If she wishes to divulge information as she have done in the past - that is her prerogative. As far as I am concerned, anything she did on orders of a legally constituted Court or Tribunal is part of a citizen's duty and she cannot be persecuted or lynched for it. Citizen's duty to the state also applies to laying information to the police about any fraud such as the ftaprosupport fraud she reported and it is her duty to report or confess as the case may be. People like you are not wanted or needed here, as evidenced by the posts here. |
Silver Member Username: Bill038Post Number: 569 Registered: Sep-06 | Nalin Nyda Gold Member Username: Nydas Post Number: 9144 Registered: Jun-06 Posted on Wednesday, March 12, 2008 - 07:06 pm: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here.. |
Gold Member Username: NydasPost Number: 9232 Registered: Jun-06 | These instructions are for Pansat2500/FLU whether converted to b75 boot or not DO NOT USE ON GENUINE PANSAT 2700 OR REAL CLONE PANSAT 2700 Preparation 1. Connect receiver to computer using a straight RS232 cable 2. Turn on racier and let it come to rest at ON or the last channel number 3. Save your current channel list. 4. If your channel list is more than 6 months old, skip all the above. 5. KEEP RECEIVER ON. Loading Boot60 '" only for new conversion to PUFF 6. Start 2700 to 2500 conversion software by Chancysand. 7. Select Boot in the Loader software. 8. Select Boot60 from the distributed software. 9. With the receiver ON, click on Write. 10. Wait for write to complete. 11. KEEP RECEIVER ON. 12. You will see horizontal night riders. DO NOT PANIC. 13. Close the 2700 to 2500 conversion loader and Loading Boot/BIN PUFF-Only for new conversion to PUFF '" must use the 640K PUFF BOOT/BIN combo. 14. Start the BL 1.4 updater. 15. Select Chancy's or jvvh 253 boot/Bin 640K file. The file name must have the word PUFF in it. 16. With receiver ON, Select BIN in the Loader and start write BIN. 17. When it has loaded it will say BURN on the loader software . 18. DO NOT SWITCH OFF. 19. When BURN is completed, your receiver will reboot and sat P-U-F-F 20. Leave it on. 21. Wait till it stops PUFFing and says ON. 22. Now switch it off. Loading latest PUFF BIN. This is the part to be repeated in future with newer PUFF BINs. You will always use PUFF BINs clearly labeled PUFF 23. In the BL update 1.4, select the latest 256 PUFF BIN and select BIN in the loader. Keep right hand on mouse ready to write. 24. Turn on receiver at the back using left hand and as soon as you see P (of PUFF) scrolling, click on Write with right hand. 25. Again wait for BURN to take place and then the receiver will reboot, go through the P-U-F-F cycle and rest with ON showing. Loading Channels. 26. Now install the channels using channel master. 27. Disconnect from receiver and connect to your TV. Do user set up and attend to autoroll. 28. First thing '" do a user setup including date.time, time zone and turn closed caption off. Blind Scan if Channel list old or not available. 29. If your channel list is good, you may skip a blind scan, otherwise do a Blind scan of your sat '" just one sat first. 30. If keys do not autoroll, go into parental control (CAS menu) and click on 'Set Default key and wait for autoroll to load the keys. It takes about 2-3 minutes. 31. You must do switch Off and On at the back in between if things are not happening as they should.. |
Silver Member Username: Bill038Post Number: 572 Registered: Sep-06 | Nalin Nyda Gold Member Username: Nydas Post Number: 9144 Registered: Jun-06 Posted on Wednesday, March 12, 2008 - 07:06 pm: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here.. |
Bronze Member Username: Rockman169Canada Post Number: 21 Registered: Nov-06 | hey you bill and lk should go play in the freeway | |
Bronze Member Username: CricpowerPost Number: 52 Registered: Jul-06 | Thanks for the instructions Nalin..somehow the picture is not as clear as it was for B75..does anybody else feel that way? | |
Gold Member Username: NydasPost Number: 9236 Registered: Jun-06 | V: On the contrary, the picture is clearer for two of my PUFF conversions and the autoroll work faster - about 1:30 minutes instead of 3 minutes. | |
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2598 Registered: Dec-06 | The PUFF things is history now.. all the bins for pansats2500a and it's clones very soon will be using only Izma-Puff .bins. CS, Loth.and UK are using this methode,Nkk is almost finishings his Izma-Puff.bin More nalyn conversion posts. |
Bronze Member Username: Snuffles07Post Number: 40 Registered: Jan-08 | 256 already? darn, i still have bin 254 and works just fine?? | |
Gold Member Username: NydasPost Number: 9307 Registered: Jun-06 | 254 works fine with DN. 256 was introduced for a BEV ECM 2 days ago. | |
Gold Member Username: NydasPost Number: 9308 Registered: Jun-06 | For those who not changed to PUFF BOOT, it is best they remain with b75 BOOT. There are at least six BINs to choose from the b75 stable. Juan Ramirezone has brought new information about yet another (and probably better) technology call IZMA-PUFF compression. Best to wait for the dust to settle. |
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2604 Registered: Dec-06 | I didn't said it don't works, what I said is, you have to convert to Izma-Puff. bin . This conversion sytem will be the only one for the pansats2500a and it's clones. I am testing the 256 Nkk-Izma-puff now, I like the way its workings, very soon the 257 Izma-Puff will be release. this is a novel system. You are late Nalyn.lol.lol. |
Gold Member Username: NydasPost Number: 9312 Registered: Jun-06 | Juan Ramirezone: Of course I am late in bringing the news. Perhaps you have some misunderstanding of English language. I specifically said, "Juan Ramirezone has brought new information" so what are you trying to say? By the way, I checked and it is LZMA not IZMA |
Bronze Member Username: Snuffles07Post Number: 43 Registered: Jan-08 | So are we gonna have boot up our receivers again or do we just overwrite the Puff bins with the LZMA bins? | |
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2606 Registered: Dec-06 | a spelling mistake, you are so mean here at ecoustics sateelite forum, but I am glad you acted like that because of you NIKK Mty, has more time for modds the 2700a bins, He is the guy that now you recommend his bins ,the NKK bins. the info was very old for me( more than 1 week) ,maybe for you was new info.lol. | |
Gold Member Username: NydasPost Number: 9315 Registered: Jun-06 | Juan Ramirezone: I don't understand why you are trying to take an offense when no offense was meant or created. You brought a piece of information, I accepted it verbatim. I had used the wrong spelling IZMA in a previous post. I saw you had used the same spelling, so I looked it up and discovered that it was LZMA and reported it here. If you don not understand how English is written you should be careful in what you say. Your ended your statement with "lol" - to some it means "laughing out loud" - except that what you are laughing about or laughing at does not exist. |
Gold Member Username: PrfrmnjPost Number: 2857 Registered: Oct-05 | You have some nerve telling people how to spell! Check your own spelling moron! Does this make sense to you: "Your ended your statement with "lol" - to some it means "laughing out loud" - except that what you are laughing about or laughing at does not exist." Learn how to speak and write before you try correcting someone on how to speak or spell... |
Bronze Member Username: PulpfiktionPost Number: 23 Registered: Mar-08 | PRFRMNJ Gold Member Username: Prfrmnj Discarded member of Gaynation.} |
Bronze Member Username: Postergirl1Post Number: 44 Registered: Mar-08 |
