New member Username: ChickletPost Number: 5 Registered: Feb-08 | Nfusion down almost an hour now... any one having same issues . i tried shutting it off and waiting 5 mins and turning it back on then updating it but it is not working Thanks for any help |
Bronze Member Username: Rafiq128Post Number: 21 Registered: Feb-08 | working ok |
Silver Member Username: ExtremexPost Number: 189 Registered: Nov-07 | Load 1.45 or 1.45.1 and bev will be back up. |
New member Username: ChickletPost Number: 6 Registered: Feb-08 | Still no luck.. red light is on but no signal |
Bronze Member Username: Rafiq128Post Number: 22 Registered: Feb-08 | not today: can you please help how to load 1.45 with remote |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2816 Registered: Oct-07 | u cannot download it yet with remote... u can only download it with webloader.. |
Bronze Member Username: Rafiq128Post Number: 23 Registered: Feb-08 | sada, hi please help how to do webloader i am new so help please thanks |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2817 Registered: Oct-07 | Not Today Silver Member Username: Extremex Post Number: 182 Registered: Nov-07 Posted on Thursday, March 13, 2008 - 12:14 am: -------------------------------------------------------------------------------- Look in your network settings menu on the nfusion. Copy down the IP address. Put that address in your web browser, try Firefox cause thats what I am using. Drop any leading 0's from the ip. For example if the nfusion is 192.168.001.101 you would use 192.168.1.101 in the browser. |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2818 Registered: Oct-07 | for microsoft internet explorer here is step by step guide with pictures.. enjoy.......... [link removed] |
Bronze Member Username: Rafiq128Post Number: 24 Registered: Feb-08 | ip is 192.168.001.102 but how to put in the web browser i have also firefox. don't know how to put the address in browser. so please help again . thanks in advance |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2820 Registered: Oct-07 | its simple.. like you put in adress bar..(firefox browser).. in simple words like this.. when you come to this site.. you put www.ecoustics.com.. right same goes with ip but don't use www... just type in. 192.168.1.102 in your adress bar.. u will get a screen.. username is admin passord is 0000 then u will see a window.. download bin 1.45 put it there and click on upload.. don't touch remote.. wait few sec.. ur nfusion rec will restart by itself..] and this will show that u have succesfuly loaded bin 1.45... |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2826 Registered: Oct-07 | so bhatti did it work for you? |
Bronze Member Username: Rafiq128Post Number: 25 Registered: Feb-08 | sada : i tried to open the browser with ip on the address but page didnot opened, so i gave up, but thank you very much for your help. |
Bronze Member Username: Rafiq128Post Number: 26 Registered: Feb-08 | sada you are very helpful i really appreciate it. I thank you again |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2832 Registered: Oct-07 | bhatti one more interesting thing i found that try to change channel with ur remote, (when you put ur ip adress in browser and press enter )... so in simple after putting the ip adress in your firefox browser , press enter and change the channel.. this might will work.. bin 1.45 will also be able to update through remote in few days.. |
Bronze Member Username: Rafiq128Post Number: 27 Registered: Feb-08 | as i sais before u r a very nice person. if u were in toronto i would invite u for a dinner, but r for away. thanks for every thing. thanks a lot |
Bronze Member Username: Rafiq128Post Number: 28 Registered: Feb-08 | said is the word |
Bronze Member Username: Rafiq128Post Number: 29 Registered: Feb-08 | I am not a computer guy so its difficult for me . I can only do if its step by step instruction |
