Conversion BINs - B75 and PUFF
Username: Nydas
Post Number: 9167
For Pansat 2500/FLU to 2700 conversions.
CHOOSE APPROPRIATE FOLDER FOR DOWNLOADING.
People who have b75 boot may continue with b75 BIN from the b75 folder.
If you have PUFF boot installed OR
if you want to convert to PUFF
choose the PUFF folder.
Username: Halo
Toronto, Ontario Canada
Post Number: 428
Whts the diff between PUFF and b75 i have pansat conversion FLU 2500-2700 and usuallly i use JVVH or Chancy so which one should i use the PUFF One???
Username: Nydas
Post Number: 9169
If you did not deliberately convert to PUFF boot in th elast 10 days or so, you have b75 boot.
Menu/system info will tell you whoic BOOT you have.
b60 boot = old file of 294T
b75 boot = Conversion file such as jvvh or CS 253
PUFF boot = PUFF_254 files
You can upgrade to PUFF using instructions in the PUFF folder in your download from
http://public.box.net/2500_full_kit
Username: Halo
Post Number: 430
Nalin if you can answer my question
Please and thnk u
Username: Halo
Post Number: 431
Thx so much for ur reply buh shud i convert to Puff i mean is the what we are going to start using now?? cas rite now i have b75 JVVH and CS so i shud use the b75 bin in ur public box so i unno shud i convert??to puff
Username: Nydas
Post Number: 9171
Right now at least one person is supporting b75 and 3 have started support of PUFF.
The people who do this work has said that "Eventually you will have to convert to PUFF"
With the 256 version you can continue b75_256 or convert to PUFF and continue with PUFF.
Username: Halo
Post Number: 432
Thx alot nalin!!!!!
Username: Micky1982
Haway, Ct Usa
Post Number: 22
i had loaded bin 254 in the last week, so which version im using nalyn,
and now, be specific tell me what to do,
Username: Nydas
Post Number: 9174
What do you mean by "be specific"? You have loaded a BIN, you haven/t even told me the name of it. You have the receiver with you and all you have to do is look at Menu/System info.
The rest of the decision making is yours.
Username: Micky1982
Haway, Ct Usa
Post Number: 26
nalyn , u make the situation more complicated by your secret answers which dont mean anything
go to the helll
Username: Nydas
Post Number: 9180
There is nothing secret. Do Menu/System info and tell me what you see.
Username: Micky1982
Haway, Ct Usa
Post Number: 28
i load bin called jvh253 bin nkk bin , before 2 weeks
and the last bin i laod it last weekk jvh 254 bin
so be specific nalyn, in the answer
what to do
Username: Micky1982
Haway, Ct Usa
Post Number: 31
i see in menue system
JVVH NKK 75 -254 EUbX
BOOT VERSION 75
MARCH 4
Username: Nydas
Post Number: 9183
DOES IT OR
DOES it NOT
SAY B75
WHEN YOU DO
MENU/SYSTEM INFO?
Username: Micky1982
Haway, Ct Usa
Post Number: 32
NO THAT WHAT I SAW IN MENUE , I WRITE IT FOR U
Username: Micky1982
Haway, Ct Usa
Post Number: 33
IS IT MEANS B75
Username: Nydas
Post Number: 9186
You have b75 boot. You can use
Jvvh_Fortec-Pansat_CanAm_256_(b75).bin
Get it from
[link removed]
http://www.dssworld.co*nr
http://www.crazyfta*com
Username: Micky1982
Haway, Ct Usa
Post Number: 36
I WANT TO CONVERT TO PUFF, WHICH BIN, THEN WHAT PUFF BIN?
Username: Micky1982
Haway, Ct Usa
Post Number: 37
TO CONVERT TO PUFF
DO I NEED TO DO DO BOOT 60, THEN DO CONVERSION TO PUFF BY JVH 253 ?.
I STARTED TO GET AN IDEAD , BUT ITS NOT CLEAR
