for those of you who have nfusion.. i wanna know did any one use wireless laptop to download file on nfusion (using a web loader)... let me know .. thanks in advance...
nottoday can you tell me how you are doing it? i will tell you my setup.. i have nfusion rec connected to router via network cable.. i don't wanna use desktop computer to load new bin b.c its really slow.. i have a wireless laptop also. so my question is this.. using my wireless laptop (windows vista).. i am going to 192.xxx.xxx web loader.. when i used the file to update it, it says page is not connecting.. etc.. gives me error message.. note: with laptop i am not using local area connection.. its wireless.. thanks in advance
What Browser? Are you using the actual IP? or are you putting in the xxx's? Have you tried putting the nfusion on a non-pay channel when loading? 100 for DN or 349 for BEV.
yeh i am using the actual ip of my nfusion.. what ever it says on nfusoion rec.. network info.. it can detect the webloader.. but when i upload the file it says. error message.. page cannot be econnected.... and when u mean ping.. u mean webloader is working..but when i download the file it gives me error
Look in your network settings menu on the nfusion. Copy down the IP address.
Turn the nfusion to a Free channel.
Put that address in your web browser, try Firefox cause thats what I am using. Drop any leading 0's from the ip. For example if the nfusion is 192.168.001.101 you would use 192.168.1.101 in the browser.
If still no go, try to ping the nfusion from your laptop. From command line type ping 192.168.1.101 or whatever your nfusions ip address is.
"If still no go, try to ping the nfusion from your laptop. From command line type ping 192.168.1.101 or whatever your nfusions ip address is" is this option is on windows vista ? where//
