Dish 500 pro for 110, 119 and 118? Can you also get BEV, on the same dish, without a motor? If not what other sat's can you add other then 129 on the same dish?
Yes the Dish 500 PRO (1 twin dish pro LNB) or any Dish 500 (2 dual legacy LNB's) can get the Bev 82-91...do NOT use the Dish 500 PLUS, thats for 110-118-119
U are confusing PRO and PLUS...
Dish 300 Single slot 18" round DBS dish that can pick up programming from one DBS satellite location at a time. DBS locations for Dish are 61.5°, 110°, 119°, 129°, 148° and (not used) 157°.
Dish 500 A two slot 18" x 20" DBS dish designed to pick up 110° and 119° simultaneously. However it can be used to pick up 119° and 129° or just one satellite location like 61.5° or 148°.
Dish 1000 A three slot DBS dish designed to pick up 110°, 119° and 129° simultaneously. This dish can be used to pick up 129° and 148° simultaneously.
Dish 1000.2 Slightly larger than a Dish 1000, its integrated head unit has 3 LNBs (110°, 119° and 129°), an input for a 4th LNB, and DP Plus switching to 3 receiver outputs.
Plus Dish 500+/1000+ Same as the Dish 1000 in function but about 5" larger and can pick up the 118.75° FSS location. As a 500+ it picks up 110°, 118.75° and 119°. Adding an LNB for 129° makes it a 1000+.
SuperDISH 105: Specifically designed to pick up 105°, 110° and 119° 121: Specifically designed to pick up 110°, 119° and 121°
