Username: Fuji905 On
Post Number: 44 Registered: Feb-07
Tuesday, March 11, 2008 - 23:29 GMT Helping a buddy get his receiver up and running. Using loader2 and latest file but I can't load the file into the receiver, nothing happens, stuck at 0%. Any suggestions?
Username: Saqeeb9000 Mughe dard rehta hai, ...,
Mujhe bhook ...
Post Number: 2773 Registered: Oct-07
Tuesday, March 11, 2008 - 23:32 GMT isn't that rec have option for usb flash drive... why not use flash drive ?
Post Number: 45 Registered: Feb-07
Tuesday, March 11, 2008 - 23:34 GMT the ultra has a USB, platinum doesn't
Mujhe bhook ...
Post Number: 2774 Registered: Oct-07
Tuesday, March 11, 2008 - 23:35 GMT i think there is something wrong with the cable u are using..
Mujhe bhook ...
Post Number: 2775 Registered: Oct-07
Tuesday, March 11, 2008 - 23:36 GMT did u ever use that cable before? did that cable came with the rec?
Post Number: 46 Registered: Feb-07
Tuesday, March 11, 2008 - 23:38 GMT same cable I used for many Pansats, just used the null adapter
Mujhe bhook ...
Post Number: 2776 Registered: Oct-07
Tuesday, March 11, 2008 - 23:43 GMT so i think u are using the laptop.. i think most of time null adapter don't work propery.. if that null adapter comes with the cd use the cd to download the driver... don't use the option for windows xp to update driver.......
Post Number: 47 Registered: Feb-07
Tuesday, March 11, 2008 - 23:46 GMT actually using PC to do this, so I guess I should the correct cable yes?
Mujhe bhook ...
Post Number: 2777 Registered: Oct-07
Tuesday, March 11, 2008 - 23:48 GMT use without the adapter.. should work.. make sure you unzip the files........... try to download the loader again...... let me know if this works..
Username: Plymouth Quebec city,
Quebec
Post Number: 789 Registered: Jan-08
Tuesday, March 11, 2008 - 23:50 GMT Sada the com probably asigned for pansat program
Quebec
Post Number: 790 Registered: Jan-08
Tuesday, March 11, 2008 - 23:51 GMT In loader2 you may set the port, just choose com1 and retry it
Mujhe bhook ...
Post Number: 2780 Registered: Oct-07
Tuesday, March 11, 2008 - 23:51 GMT what do u mean plymouth?
Quebec
Post Number: 791 Registered: Jan-08
Tuesday, March 11, 2008 - 23:59 GMT Is this a cable USB to RS-232
Quebec
Post Number: 792 Registered: Jan-08
Wednesday, March 12, 2008 - 00:19 GMT Sada if it RS-232 to RS-232 the computer keep last program use port. He need to reassigned port for new program. If USB to RS-232, he need to turn on his box and connect USB for detect it, if dont work reboot computer without USB and eaconnect with his box on and retry to download That what i mean Thanks
Quebec
Post Number: 793 Registered: Jan-08
Wednesday, March 12, 2008 - 00:20 GMT Sada if it RS-232 to RS-232 the computer keep last program use port. He need to reassigned port for new program. If USB to RS-232, he need to turn on his box and connect USB for detect it, if dont work reboot computer without USB and reconnect with his box on and retry to download That what i mean Thanks
Mujhe bhook ...
Post Number: 2781 Registered: Oct-07
Wednesday, March 12, 2008 - 00:21 GMT ok yeh try this chris.. this will work....i hope,,
Username: Nub2fta N/a,
N/a
Post Number: 146 Registered: Aug-06
Wednesday, March 12, 2008 - 00:33 GMT also... make sure the zmodem window is open before you turn on the receiver when you see this, do it. -> Status: Sending ZRQINIT... nub.
Post Number: 48 Registered: Feb-07
Wednesday, March 12, 2008 - 00:35 GMT no, doesn't work, I'll have him bring the cable in that came with the stb, thanks guys!
