Here is a list of different LNB's Originally posted by: odd thomas
There are 2 different types of Ku band LNBFs; 1=circular lnb=lo 11250 mhz, 2=linear lnb, linear has 3 different types of frequency, 1= universal =l.0=9750mhz-10600mhz (Europe model), 2=universal= l.0=9750mhz- 10750 MHz, ( US model's, use both also called wide band LNBFs), 3= standard =10750mhz
61.5'w echo3 = use standard circular lnb = 11250 MHz 63'w estrela = use linear lnb, either universal or standard linear=10750 MHz 71.8w nahuel1= linear lnb, either universal or standard linear= 10750 MHz 77'w echo 4= circular standard lnb= 11250 MHz 79'w amc 5= linear lnb, either universal or standard = 10750 MHz 82'w nimiq 2= circular standard lnb= 11250 MHz 87'w amc 3 = linear lnb, either universal or standard = 10750 MHz 91'w galaxy 11= linear lnb, either universal or standard=10750 MHz 91'w nimiq1&3= circular lnb standard= 11250 MHz 93'w intelsat 6= linear lnb, either universal or standard=10750 MHz 95'w galaxy 3c= linear lnb, either universal or standard= 10750 MHz 97'w intelsat5= linear lnb, either universal or standard= 10750 MHz 101'w amc 4= linear lnb, either universal or standard= 10750 MHz 103'w amc 1= linear lnb, either universal or standard- 10750 MHz 105'w amc 15= linear lnb, either universal or standard=10750 MHz 107.3'w anik = linear lnb, either universal or standard= 10750 MHz 110'w echo 8 & 10,X = circular lnb standard = 11250 MHz 111'w anik f2 = linear lnb, either universal or standard =10750 MHz 116.8'w satmex5 = linear lnb, either universal or standard=10750 MHz 119'w echo 7 = circular lnb standard = 11250 MHz 121'w echo 9 = linear lnb, either universal or standard = 10750 MHz 123'w galaxy 10r = linear lnb, either universal or standard =10750 MHz 127'w galaxy 13 = linear lnb, either universal or standard = 10750 MHz 129'w echo 5 = circular lnb standard = 11250 MHz 148'w echo1&2= circular lnb standard = 11250 MHz
MINGO ARIZA fix for ARIZA 700 700s 750 & 800 FEB 26 2008 ________________________________________ Here you go Guys / Gals as always posted here FIRST only at [link removed]
