Silver Member Username: Pathfinder191Post Number: 341 Registered: Mar-06 | My Pansat 2700 A (original) is showing no signal and some scrambelled channel with bin 250. I tried factory reset, factory flash and again bin 250 but nothing works. Could anyone please tell me what the problem is? Thanks, Sam |
New member Username: MosayPost Number: 1 Registered: Nov-05 | off on the receiver first and see |
New member Username: PgomesPost Number: 8 Registered: Jan-08 | Same problem with me, and did the on off. BTW I used the Lothario bin. |
Silver Member Username: Pathfinder191Post Number: 342 Registered: Mar-06 | Mohamed, I tried that too, did not work. |
Bronze Member Username: HangonPost Number: 44 Registered: Sep-06 | Reload the BIN, mine is working just fine. Or try another 250 bin. I am testing AV 250. |
Gold Member Username: NydasPost Number: 8179 Registered: Jun-06 | Sam has a genuine Pansat 2700. P Gomes has a converted 2500-2700. Why are you mixing me the two in one thread? Sam: You said "Factory flash". Did you reload B75 using loader 27.02 If so, did you use 27.03 to load the X-87 BL 250 BIN? Did you do User setup? |
Silver Member Username: Pathfinder191Post Number: 343 Registered: Mar-06 | Thanks Nalin, I used loader 27.01 for factory flash and 27.02 for 250. I did not do User setup and I don't know how to do it. Kindly help. Thanks again, Sam. |
Gold Member Username: NydasPost Number: 8180 Registered: Jun-06 | Is it saying "b-7-5" when you turn on? About default setting or Factory setting, it is 5th on Menu. Use Setup is 4th on Menu. Put in date/time and disable the closed caption |
Silver Member Username: Pathfinder191Post Number: 344 Registered: Mar-06 | Yes, it does say b-75 when I turn it on. I will try the rest of your suggesions and post my experience. BTW, using two different versions of loades for loading factory file and current file make a difference? Thanks in advance |
Gold Member Username: NydasPost Number: 8181 Registered: Jun-06 | I have heard of the "two different versions of the loader". Right now it would be difficult to get into future-fta, but you could get the loader afresh from ftatalk or al7bar I think you are experienced enough and should not be having these problems. |
Silver Member Username: Pathfinder191Post Number: 345 Registered: Mar-06 | Ok, I used 27.02 loader for factory file and 250 bin. It solved the problem to some extent but still goes to scrambled channel/no signal after every few minutes. |
Gold Member Username: KirankumarKenya Post Number: 1624 Registered: Oct-07 | Sam, your dish hasn't moved ,has it? |
Silver Member Username: Pathfinder191Post Number: 346 Registered: Mar-06 | No, I have SonicView 1000 too and it's working great. |
Gold Member Username: KirankumarKenya Post Number: 1625 Registered: Oct-07 | ok it might be a bin problem |
Silver Member Username: DannienjuliePost Number: 142 Registered: Jul-07 | ok i load the bin for my 2700 quantum box and the green light that go back and forth what do i do plz |
Silver Member Username: DannienjuliePost Number: 143 Registered: Jul-07 | does the box have to be connected to the sat. while putting the bins in. all i get after complete is a green light going back and forth |
New member Username: DglezPost Number: 5 Registered: Feb-08 | Load BIN 250 Set default key and let it roll. |
Silver Member Username: DannienjuliePost Number: 144 Registered: Jul-07 | ok i ll try that but how long does it take to reboot |
Silver Member Username: DannienjuliePost Number: 145 Registered: Jul-07 | why is my box showing a green light going back and forth when i load the bin after it completes just a green line back and forth help plz |
Gold Member Username: NydasPost Number: 8203 Registered: Jun-06 | "2700 quantum box" Please give the proper name as written on the box and some other details of its history.. |
Silver Member Username: DannienjuliePost Number: 147 Registered: Jul-07 | my box has quantum 4700 DiSEqC 1.2 on the front of it. I bought it from this guy about 2 years ago. He hooked it all up. Everything was working fine until a couple of months ago, then all the PPV stopped working All I had to do was put the new keys in. I didn't know anything about the bins. Now nothing works on them. (I have 3 boxes) Can any give me step by step instructions on what to do Please.} |
Gold Member Username: NydasPost Number: 8213 Registered: Jun-06 | I have answered you in another thread. You loaded a clone killer original BIN into a clone. You need to jtag. |
Bronze Member Username: Kimo74Post Number: 64 Registered: Jan-07 | hi Nalin i have a faviour to ask you. could you have on forum for the converted fortec to pansat receivers so we can all open it and know all the updates, and we don't have to search the whole web site to find you. 2- when you post files on your public box, i find it hard to know which file i should load into the receiver because i find too many files and for someone like me who is not good in these stuff i find my self lost. i know i am asking too much put please that will make life easy on us. the other thing i have loaded CS_250T_Lightning_100t_Series_serial to my converted fortec and it gives me bad channle in the BEV i am not sure why. |
Bronze Member Username: Kimo74Post Number: 65 Registered: Jan-07 | lol sorry nalin i mean favor. i know how hard you try to help us, and i am asking too much too but i know how nice and kind is Nalin that's why i am asking too much. |
New member Username: KenbelkOntario Canada Post Number: 8 Registered: Nov-06 | Hi Nalin, I am loading with loader 27.02 from the 9 pin com port which is not a problem, the problem is that port is obsolete on new laptops.I converted a usb port to com port on the my laptop and tried to run the loader.I got a message informing me that the program did not reconize that port. do know of a sulution |
Gold Member Username: NydasPost Number: 8220 Registered: Jun-06 | There are at least 20 discussions on this subject in this forum in the last 2-3 months. USB to serial: 1. Buy the adaptor with its own Driver Cd. 2. Override Microsoft and use CD during installation. 3. Make sure you set the COM port to 1, 2, 3 or 4. 4. Check via the Device Manager that you have correct setting. 5. In your Loader use the COM port you have set. 6. If you are not sure of the cable you have, have a DB9 M/F Null adaptor handy so you can use the cabling with it in or out. USB to serial is easy with Window 98, more problemetical with XP and even worse with Vista. There are couple of URLs in the previous discussions about getting specific drivers. |
Bronze Member Username: Kimo74Post Number: 66 Registered: Jan-07 | is bev working or it is down plz answer |
Gold Member Username: NydasPost Number: 8228 Registered: Jun-06 | DN is down. For Pansat 2700A/E, clones, and conversions, BINs 227, 232 abd 235 are said to be working. For people who are using Conversions, you can get these BINs from http://public.box.net/2500_full_kit File: Old_227-232-235.zip These old BINs are for Conversions only. DO NOT use on genuine 2700 or on clone 2700 |
Bronze Member Username: Kimo74Post Number: 67 Registered: Jan-07 | hi all, hi Nalin i am not sure what's wrong, but i still don't have BEV. Nalin Could you please tell me what is the latest file is should load into my converted FU to have BEV. I have followed all the instructions and it is not working. pleaseeeeee help |
Gold Member Username: NydasPost Number: 8274 Registered: Jun-06 | kamal: BEV IS NOT WORKING ON ANY PANSAT |
Bronze Member Username: Kimo74Post Number: 68 Registered: Jan-07 | Nalin: THANK YOU VERY MUCH BRO. |
