Gold Member Username: SatgrlOuTa yeh DuniyA Post Number: 1451 Registered: Oct-07 | ok i got this viewsat i loaded the latest bin from ftaforall...and its still saying autoroll processing on DN 61.5...every other receiver i try to fix it works but i dont know why everytime i try someones viewsat xtreme it like never works..im using loader2 and bin DBPSW-080211X.zip ....help if u can thanks |
Bronze Member Username: Leo_herePost Number: 50 Registered: May-06 | Hello Miss Outta This World ! I am not sure about other boxes but I have experienced the same issue with my VS Extreme. Try. factory reset, this will clear it all out, then setup antenna settings, and then scan again, f1, not a blind scan, and do one sat at a time, saving each one as you go.... Good Luck ! |
Silver Member Username: Jwl1Post Number: 132 Registered: May-06 | I believe this issue was discussed under: HEEEELLLLLPPPPPPPP!!!!!!!!!!!!!!!!!! (I hope that is the right one) |
Silver Member Username: Madflea168Post Number: 233 Registered: Jan-08 | check out this thread made by the FTA tester. https://www.ecoustics.com/electronics/forum/home-video/431069.html after the bin loaded, switch off from the back and let sit couple of minutes before reboot, it will help the new bin and auto roll to kick in. |
Silver Member Username: Koko_wawaPost Number: 219 Registered: Aug-07 | after the files downloading reaches 100P, you have to see ins.t, followed by end, then 0000. This means the file was successfully downloaded. Turn off from the back, connect to the cables, turn on and it should work. Good luck. |
