Nalin Nyda or Oleg Need help please
Username: Mriaz
Post Number: 53
Hi there!
I have a problem with my pansat converted to 2700. Some how my signal disapear. When I press on remote (SIG) it take me to the (SKEW) signal window on TV. There are two BAR, one for LEVEL and the other one for SIGNAL. Level is ok 90%, but signal is 0%. My all TP, all setting and connection is fine, because i am running same other receiver on it and that is working fine.On top of the BAR is written UNLOCK instead of LOCK. So How can i get signal in LOCK. If you can help me or anyone i will be appricate it. I am waiting for your sulotion please.
Username: Oleg1474
Florida Usa
Post Number: 931
www.Future-FTA.info.com Thank you!!
Username: Saqeeb9000
Post Number: 2163
RIAZ... WHO TOLD U TO ASK OLEG... HE IS AN IDIOT....
Username: Kirankumar
Kenya
Post Number: 1419
Riaz,
Oleg works at a circus feeding the animals,don't listen to him
Username: Mriaz
Post Number: 54
Where is Nalin Nyda
Username: Oleg1474
Florida Usa
Post Number: 933
www.Future-FTA.info
Kenya
Post Number: 1420
he probably went out to eat ,he'll be here.you just have to wait
Username: Mriaz
Post Number: 55
Ok
Username: Nydas
Post Number: 8002
Looks like memory corruption.
Note down your Antenna settings.
Do factory default settings.
Do TV setting.
Switch off at the back - Switch on after 1 minute.
Do Dish setup - One antenna setup only.
Do Blind Scan (Power Scan)
Do the other Sats.
Username: Mriaz
Post Number: 57
When you say down your Antina settings and Do TV setting. Can you explain how do i do it please
Kenya
Post Number: 1422
he means write down what your antenna settings are now
Username: Mriaz
Post Number: 59
At ECHO 3KU 61.5
LNB Type Standard
LNB Local-freq 11250
22KHz OFF
Dis SqC 1
Legacy SW NON
Skew -45
TP 12326
Psitioner setting Diable
Setalite Scan ALL
For ECHO 7KU 119
LNB Type Standard
22KHz ON
Dis SqC 2
Legacy SW NON
Skew 45
TP 12239
Setalite Scan ALL
Above setting i have on my FLU
