Hi, I loaded bin PFTAUSW-080204U to my vs ultra and did the antenna settings but all I get is NO VIDEO NO AUDIO. One channel shows the coming Chavez fight next sat. Also how can I find CODE MODE to change keys?
Fac Default,Recheck your settings and Rescan: Satellite..............EchoStar 8,10 (110°W) LNB Power .............ON LNB Type...............OSC-DP (If you have DP LNB, otherwise set it to STANDARD) LNB Freq...............11250 22KHz..................OFF TP Freq................12224 DiESqC 1.0.............Port 2 Motor..................OFF Legacy SW..............None
Satellite..............Echostar 7 (119°W) LNB power..............ON LNB Type...............OSC-DP (If you have DP LNB, otherwise set it to STANDARD) LNB Freq...............11250 22KHz..................OFF TP Freq................12239 DiESqC 1.0.............Port 1 Motor..................OFF Legacy SW..............None __________________
