Any File for Converted Pansat Clone?
Username: Dishlover
Toronto, Ontario Canad
Post Number: 113
Where are JVVH or Chancysand's files for latest fix. Please advise.
Username: Brucester
Post Number: 1137
there not out yeat did you see them when you where overe at crazy tacking my files you pice of crap
Username: Dishlover
Post Number: 115
Shutpup
Username: Nydas
Post Number: 7634
The Converted receiver files are usually 3-6 hours AFTER the main Pansat 2700 BIN is published. Keep an eye on future-fta.info site and when the new 2700 file is announced there, you can expect it 3-6 hours later.
Username: Dishlover
Post Number: 116
Thanks Nalin.
Username: Nydas
Post Number: 7640
Tamara: Check you hostclip URLs elsewhere in the forum. They don't work.
Username: Espn3
Post Number: 221
Nalin, Tamara, when the DN fix for the FLU converted to Pansat 2700 is available please post were it can be found. thanks.
Username: Pch
Hey Guys
BEV bin 243 can be found at dsstester.c0m
for BEV only - It works nice (-_-)
good luck
Username: Nydas
Post Number: 7642
pe ce ech : You should understand that there are different BINs for Pansat 2700, clones and conversions. The question here is about conversion BIN, not the real Pansat 2700, and for DN ECM of 24th January.
THERE ARE NO DN FIXES AVAILABLE YET FOR PANSAT 2700, 2700 CLONES, AND FOR 2500 TO 2700 CONVERSIONS.
Username: Pch
Yes sir ! I understand very well
I always read your message and used your INFO
to convert my box to I of my pansat 2500 clone to 2700
I know that this site not alow the word dsstester.C0M but I just want to help whoever has
the converted box like mine can watch BEV
(Fortec or pansat remote bin 243 for BEV is working nice !!!!)
Anyway If I made you and anyone here upset please fogive me
(-_-)
Username: Nydas
Post Number: 7645
dsstester site has had too many false BINs posted there, even as recently as 4 weeks ago. That's why I would urge caution.
Username: Tonyg2000
Is the pansat 3500 bin the same as the quantum 3500.
Username: Tonyg2000
is there a bin for that yet
Username: Pch
OK Nalin
a cheap person like me I always USE cheap Stuffs as long as I know where to get them
By the way I sory to use the word DESSTESTER.C0M
try to type the word dsstester.C0M into this forum see if you could do it
Bye and good luck
I beg your peace !
Pe ce ech
(-_-)
Username: Nydas
Post Number: 7652
Pe ce ech: Don't worry. Everything is fine. There are few sites that Ecoustics does not like because of many user complaints. Then they do not allow the name in full, and people get around it by using names that are close to it (the way you did) or sometimes they use * instead of . and sometime they use the word "dot" instead of .
Username: Zeez
San Mateo, CA USA
Post Number: 16
Nalin Nyda, you are always a great help to everyone ... thank you
Username: Pch
hi hi hi ... very cool Nalin
have you try that bin 243 for bev yet
I watch TV since 24th
Try It my friend ! It's free, You have nothing to loose ... packet it up and send it to your data warehouse and share with your fans I
am your fan too in this site !
By the way my name pe ce ech in some language
mean Uncle FROG - I jump I don't walk
(-_-)
Username: Dishlover
Post Number: 117
If those links not working these can be found at dssworld.
Username: Nydas
Post Number: 7669
pe ce ech : Thanks for the Info on the 243 BIN.
I have tried the CS_243 and the jvvh_243 for Pansat Remote and they both work well for BEV. I had given my approval to a friend two days ago who posts them and the conversion routine with instructions that I wrote originally.
Try and look at:
http://public.box.net/2500_full_kit
Username: Nydas
Post Number: 7670
By the way, the 244 file for the real Pansat 2700 is out now.
x-87bl_080126_b75_244_api.zip
This file can be downloaded from
[link removed]
It is only good for BEV and for real Pansat 2700 - not suitable for clones and converted receivers.
Username: Pch
Nalin
see u around my friend ! It's time for me to jump back to my hole
(-_-)
