Viewset Pro bin
Username: Frobi
Post Number: 169
Any one having problems with VS Pro latest bin? Mine has been autorolling since 15 minutes. Switched off from back, quality and signal over 80%, and every thing is normal.
Username: Jurj1
Post Number: 459
make sure autoroll on, if it is try entering key manually first time.
Username: Madflea168
Post Number: 144
mine works fine with gui 2, only thing is does not change channel as fast as xtreme.
Username: Frobi
Post Number: 171
Thanks Tony Soprano and Mad Flea. Reloaded the bin and is working now.
