Need help converting back to original fortec
Username: Khova
Post Number: 12
hi i was going to start from the beginining due to a error how do i revert back to a fortec after i converted it to a pansat 2700.. and its a fortec clone if that matters
Username: Khova
Post Number: 13
really need help
Username: Vyizder_zomenimor
Post Number: 42
You may need to jtag your box but there is a 2700/2500 serial process out there. Question is, why would you want to convert back to 2500?
Username: Khova
Post Number: 14
because i had someone do it for me, want to start over and do it for myself, sounds stupid but just in case my friend cant do i want to know how to operate this and i dont think i need to jtag it it turns on
Username: Khova
Post Number: 16
so how would this be done
Username: Rtap
FL
Post Number: 1752
there are files to convert it back to a 2500
Username: Khova
Post Number: 17
were can i find it
Username: Nydas
Post Number: 7491
The full kit is in full_kit11C.zip. Unzip into a new jvvh directory. and read the instructions in the Instructions.doc file.
It includes a subdirectory "Revert to 2500" with Cahncy's instrructions
http://public.box.net/2500_full_kit
Username: Nydas
Post Number: 7493
It includes a subdirectory "Revert to 2500" with Chancy's instructions
Username: Popol_vuh
I signed up here to thank you, Nalin, for your selfless and generous help. You truly are a shining star among the riff-raff.
Kudos buddy, keep up the good work :-)
Username: Nydas
Post Number: 7501
Bi½ppler Ceh : Thanks. I try to keep on top of things.
Username: Khova
Post Number: 20
thanks nalin
Username: Khova
Post Number: 21
so i would be able to use the 2500 loader to revert back on my fortec?
Username: Nydas
Post Number: 7531
manu: Why are you asking questions instead of downloading reading for yourself?
