Silver Member Username: Dure
Mississauga,
Ontario
Post Number: 162 Registered: Jun-06
Posted on New file for Clone Pansat 2700 pl.(Not converted). Can I use jvvh 242 for clone Pansat 2700 |
Gold Member Username: Nydas
Post Number: 7508 Registered: Jun-06
Posted on "Can I use jvvh 242 for clone Pansat 2700" NO....N O.....N O O O O..NO NO NO |
Mississauga,
Ontario
Post Number: 163 Registered: Jun-06
Posted on Thank you Thank you Nalin |
Silver Member Username: Vittu
Post Number: 113 Registered: Oct-07
Posted on Which file is working for BEV. I have FLU converted to 2700. Thanks |
Bronze Member Username: Saadiaa
Post Number: 54 Registered: Nov-07
Posted on u can find the latest file on dssworld. co. nr. for converted flu...I think it is 232. |
Silver Member Username: Way2smart
Http://desifta.co.nr/
Post Number: 639 Registered: Oct-06
Posted on or go to desi fta <--------------- desi fta |
Post Number: 7520 Registered: Jun-06
Posted on vittu, sadia, Smart 1. There have been a lot of problems with confusion between Pansat 2700, Pansat 2700 clone and 2500-2700 conversion. There are three different files. Please, keep the threads separate. This thread was for Pansat 2700 clones not for conversion BINs. |
