Please help...
Username: Deptrai_cachon
Post Number: 9
I have Direct TV (dish) -- can I still get signal for dish network ??
Username: Rtap
FL
Post Number: 1744
if you have phase three dish you can only get either 110 or 119 not both.
Post Number: 12
no i meant i want to use that (direct tv dish) to receive dish network signal. will it work ?
or it has to be ( dn dish ) for dn signal !
Username: Rtap
FL
Post Number: 1746
ken you can use it. you can only get either 110 or 119 not both
Username: Jayson
Post Number: 94
yeah....it works...I think you'll need a different LNB
Username: Tale
Post Number: 134
KEN, you can use any dish to receive DN signal.
Username: Nydas
Post Number: 7514
KEN: Ignore the nonsense. Me ta and jayson are right. A Dish can be used as a Dish - as a reflector. The LNB(s) you might have will be peculiar to DTV and will not get all that Dish might offer. The LNB(s) have to be changed and you will be able to get Dish Network with appropriate LNB(s).
