Need help with Lava 3200 converted
Username: Palau
Hercules, Coahuila Mexico
Post Number: 8
Hi I am trying to DL bin jvvh_fortecRemote_240_zip into my Lava 3200 converted, using loader 1.4.0 and everything goes ok until after burning loader says write failed. Can anybody help?
Username: Runnerguy
Pluto
Post Number: 1078
Check your cable, make sure it's the correct one and recheck your connection.....make sure file is unzipped..hope this helps
