Nalin Nyda i need your help?
Username: Ninjad
Post Number: 28
sorry to bug you but i been looking for a way to update my fortec star lifetime ultra. Been searching for over an hour with no luck. can you plz help me get what i need? bin and loader for this box plz. thanks
Username: Mcrabbycabby
Wpg, Man Canada
Post Number: 30
hello nalin which is the best bin for my pansatn2
Wpg, Man Canada
Post Number: 31
sorry its a 2700
Wpg, Man Canada
Post Number: 32
thank you nalin i found the answer in a diff thread also thanks for the tip on downloading at the b i could never get it till i read what you said lol except when it was the wrong file and burnt me out.
Username: Nydas
Post Number: 7384
Terry: Pansat n2 seems to be a Pansat 2700 clone.
The latest clone safe BIN is
Pansat-C 2700 240v1 Tivo
Your receiver should show b-7-5 scrolling horizontally when you turn it on. If it is not, then upgrade to b-75 BOOT using
Clone_2700_Upgrade_Package_v201(b-75)
Do not use the genuine Pansat 2700 BIN and do NOT use the 2500/FLU conversion BINs with names starting as jvvh_ or CS_
Username: Nydas
Post Number: 7385
David: The following is for you and NOT for Terry.
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
In case you have difficulty getting the latest BIN, it is available here.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest CS_240T_lightning file
The latest jvvh_239 files for Pansat or Fortec remote '" for DN fix
The latest jvvh_240 files for Pansat or Fortec remote '" for DN fix
The newest jvvh_240 files for Anik3 scan '" for DN fix
Some of the older versions and jtag files are also included.
http://public.box.net/2500_full_kit
The full kit is in full_kit10zip. Unzip into a new jvvh directory.
The 239 version and 240 version conversion files are available separately as well.
