Flu converted....i'm still down....
Username: Jaye50
Post Number: 61
running my converted flu....i've tried every bin...239....240....jwh and cs....and i've still got the same channels i had with the ecm.....i've got network feeds and that's it..... jwh 239 did try to autoroll....the rest just gave me bad channel....i've tried everything and nothing works....
just took my fta valium....i'll try again when it kicks in....altho i don't know what else i'll do...
signal is great as is quality....but on all bins....nothing but network feeds
Username: Nydas
Post Number: 7377
What sats are you scanning?
Username: Jaye50
Post Number: 62
echo 8 and echo 7 .....
Username: Nydas
Post Number: 7387
Your best bet is to clean up the memory.
After loading jvvh_240. Here is a C/P from instructions in the full_kit10B.zip
DO NOT USE CHANNEL LIST.
E. Connection to TV:
1. With receiver switch in off position, connect the Sat antenna, and the cables to TV.
Turn on TV
Turn on receiver.
You will see b75 go across and freeze on '5'.
WAIT
After a little while the TV will come on asking you to confirm Language
English.
Press OK.
2. First do Menu/ default settings (Factory default)
It will ask for PIN '" use 1668 if you have forgotten your PIN, usually a 0000.
3. Next do User setup. Set time to manual and enter the correct time, date, and time zone.
Make sure summer time is off.
4. Next do Menu/Dish Setup/Antenna setup
Select your known dishes and use the known DisEqC port connections.
You can connect to ports without knowing which is which using trial and error and the signal strength.
Now do Blind scan (power scan) for each of the selected sats.
You must see Vertical TPs.
Username: Nydas
Post Number: 7388
In your case, you should keep 110 disconnected in antenna setup and do blind scan of 119W as Port 1, then disconnect the 119W in setup and do a Blind scan of 110 with either Port 2 or None setting.
Username: Jaye50
Post Number: 63
when the valuim kicked in....i took the switch off alltogether....put in a coupler and just ran the line to echo 7....then i set echo 7 to no switch....then i loaded jwh 240 back in....when it came back up i was about to follow your directions but the programing was there....gonna leave it like it is tonight.....and just enjoy what i've got and the valuim til tommorrow.....
i know they've got you hopping tonight....so thanx for taking the time out....
