What channel scan is better ?
Username: Nyc_alien
Staten island, Ny Us
Post Number: 100
Which channel scan is better? Is it blind scan or advance scan or network scan ?
Username: Nydas
Post Number: 7306
Blind scan gives you the current TPs, because it finds the TPs first and then scans the channels.
I find that the best, because it gives me the least of problems with "searching for signal".
Username: Rtap
FL
Post Number: 1720
may duplicate your channels
Username: Nydas
Post Number: 7315
Few duplicate channels do not hurt anybody if they know how to use the favourites.
Persistent interruption for searching for channels hurts a lot.
Username: Scabz
Knoxville, Tn Us
Post Number: 308
So, if I do a blind scan I will get more tp's ?
Username: Way2smart
Http://desifta.co.nr/
Post Number: 485
Channel master the best and the fastest
Username: Nydas
Post Number: 7325
scabz: A blind scan (Power scan) is the only scan that looks for the current TPs. It then finds all the TPs and gets the channels for all the current valid TPs.
Username: Pulp_fiction
Post Number: 1077
