Searching Signal VS Ultra
Username: 4azeef
Post Number: 17
My receiver kept saying sercing signal. it was working fine until yesterday. i did hard reboot 3 times still same thing. would it have anything to do with high wind? anyone having same problem in ON, Canada?
Username: Pressmanjr
am having the same problem, and am located in ON. Checked all the connections and all are in tact.
Username: Ke5aqn
Post Number: 3276
https://www.ecoustics.com/electronics/forum/home-video/431069.html
Username: Nydas
Post Number: 6964
Did you install the latest Viewsat Ultra BIN?
PFTAUSW-080108U-1.zip
It is dated yesterday and available at
[link removed]
Thanks for the info.
Followed the steps in FTA TESTER's link and loaded the latest Ultra bin...still no luck.
Bare with me as I'm new at this, but I have S in the 60's but no Q. As of yesterday both were in the 80's and 70's. Does S mean I have a signal? Any advice would help.
Username: Bill038
Post Number: 419
S means your viewsat is talking to your lnb's. 0 Q means you are not getting any signal from the sat to your lnb. Maybe your set up or maybe your connections, maybe your dish has moved.
