VS Extreme/super dish setup???
Username: Sluggp
Post Number: 17
I have a VS extreme with a super dish and a HD LNB. My settings are:
sat 119 = port 1
sat 110 = port 2
sat 129 = port 3
lnb freq is 11250
lnb type is ocs-dp
legacy SW is none
are these the correct settings for this setup? will this get me all DN channels?
thanks in advance
Username: Sluggp
Post Number: 18
oh...and I'm using a dp34 switch
Username: Grimreeper
Post Number: 334
Yes they look ok but youll most likly have to hook a dn receiver to port one on the dp34 switch to power it because the viewsat power regulator does not do good at powering these switches
Username: Madflea168
Post Number: 15
it is said the xtreme supposed to able to power up the dp34, but actually no, not even with 2 xtremes hook up to the dp34.
you will need a dp adapter or some sort to give more juice to the dp34.
connect the adapter alone as one of the receivers, if you connect the xtreme to the adapter like the instruction said, xtreme will not work right.
Username: Nydas
Post Number: 6959
Without supplying adequate power you may actually damage your Viewsat. Best thing is to get an old DN receiver and connect it to port 1 output of DP34 as suggested by Grim above and keep it on
Username: Sluggp
Post Number: 19
if i dont have an old reciever would the adapter work?
Username: Nydas
Post Number: 6963
Yes, as long as the power supply is not solely form your Viewsat receiver.
Username: Sluggp
Post Number: 20
thanks for the help guys!! i will try it out!!
Username: Fta_brotherhood
CHEEK OUT ftabrotherhood.com
