CS_235T_Light_100t_series_ serial bin FLU & 2500 to 2700
Username: Jkmago
Post Number: 129
ALL IS UP D/N & BEV
THIS IS FOR PEOPLE THAT BEEN CONVERT TO 2700, AND DO A FACTORY RESET TO GET ALL SATS
Link
http://www.satnow.info/forums/showthread.php?p=90559#post90559
Cheers!
Username: Jkmago
Post Number: 130
Files at
http://www.satnow.info/forums/showthread.php?p=90556#post90556
Username: Bdsingleton24
Post Number: 14
Are these the real deal?
Username: Jkmago
Post Number: 131
Yes , usually they are always very fast and files are all good.
Username: Kingofdakingz
Post Number: 122
YES TESTED AND WORKING GUYS THANKS cs
Username: Ather_da_don
Mississauaga, Ontario Canada
Post Number: 249
Is this for clone pansat converted 2500 to 2700??!!
Post Number: 15
What loader do I use for this?
Username: Jkmago
Post Number: 132
Yes for converted
Username: Locnoir
Post Number: 29
Jodi or anyone, could you please upload the file for converted pansat 2700 here? Thanks
Username: Suketu90
Toronto, Ontario Canada
Post Number: 18
i am getting "scrambled or bad channel" for my bev even after loading the 235 file
help!!!!!
Username: Ash64
Post Number: 60
register and download..its that easy !!! add site to fav for future use..ok??
Username: Leafs
Post Number: 292
new pansat clone bins posted at www.ftasolutions. blogspot.com (remove space)
Username: Jkmago
Post Number: 134
Working Great for Converted
Cheers!
Username: Gmanrus
Post Number: 82
This file is broken, what can I do?
Username: Srg200159
Post Number: 65
can someone send me the 235 clone bine thank you
Username: Jkmago
Post Number: 135
Download the second file only
Username: Chichos26
Post Number: 38
suketu patel
after loading 235T serial bin and if you get scramble hit 8282 on remote and do a set key default }
Username: Jkmago
Post Number: 136
if finding problem in downloading
here is another link
[link removed]
Username: Bomberman
Post Number: 136
http://rapidshare.com/files/81023776/CS_235T_Lightning_100t_Series_serial.bin.ht ml
download the file from this link, it's working great and i feel the video quality is also better with this bin
you will often get scrambled or bad channel switching between sats, so just give it like 5 sec for the video to appear
Username: Gmanrus
Post Number: 83
I installed the 235T bin, all 110/119 channels are working great, but 61.5 international channels don't work at all, even after long period waiting (approx. 7-10 min.) - it says: Scrambled or bad channel.
Post Number: 16
scrambled or bad channel keeps appearing and does not go away???
Username: Locnoir
Post Number: 30
Thanks,Bomberman!
Username: Lucia
Calgary, AB
Post Number: 444
i get scrambled channel too!
Username: Gmanrus
Post Number: 84
bdsingleton24: that's right, I've been waiting for more than 15 min. and I still get Scrambled or bad channel!
Username: Bomberman
Post Number: 137
try set default key, and then let it autoroll that should work, also make sure you turn autoroll off for all providers, and maybe also switch it off/on from back, i just checked mine and it is working for echo 3
Post Number: 18
still nothing, i did set default key, after that it never autorolled because you said turn them off... i switched it off/on, and still nothing??
Username: Bomberman
Post Number: 138
it should autoroll regardless whether you turn them off or not, but anyway, turn them onn and then let it autorll, after that if you get scrambled and bad channel, just let it stay there for 5-10 sec, the video should come up, if it still doesnt then try waiting on another channel, and then again if it doesnt come up, then your attenna settings are incorrect
Username: Gmanrus
Post Number: 85
Can anybody tell me if u have channel 594 working, ok?
Post Number: 19
ok it still didn't work...do you know how i might fix them?
Username: Halo
Post Number: 297
bdsingleton24:
Umm try entering the keys in manually or jus keep setting defult keys cas thts wht i did and i got it working for me buh u want u can get the keys from www.dish-keys.blogspot. com (no spaces between the .com)
Post Number: 252
The clone is at these three websites:
www.ftasolutions.blogspot. com
Post Number: 253
The Clone BIN File for Pansat 2700 is at these three websites:
Username: Koku99
Post Number: 51
I can't belive my olf fortec beat viewsat ultra. I bought 2 viewsat ultras two weeks ago thinking my fortec was done. I am now using my fortec insted of the ultra with the 235 bin and it's working great. Who would have thought. I'm still going to give viewsat the benefit of the doubt. We'll see in february if they get the full emu. If they do they will be kings of fta once again. Right now they are the duds of fta.
Username: Sjain80
Post Number: 126
i had also given up on fortec..I have been using viewsat platinum for a while but this fortec comes in handy many times. It is the oldest receiver but still coming thru for me..
Username: Tinfish
Post Number: 140
Jippi..not working for 121. I'm sure my settings are correct. satys on scrambled or bad channel forever.
Username: Shadow45
Mty, Nuevo Leon Mexico
Post Number: 224
Thanks for the bin jippi.
Username: Viruscauser
Leesburg, Georgia
Post Number: 701
Thanks for the quick link, Jogi Mago. Works great.
Username: Soft_guy
Does this file works for 61.5 International Channels??
Leesburg, Georgia
Post Number: 702
Yes it does - but only for the 2500>2700 converted receivers.
Username: Letmeon
Post Number: 172
235T when turn on receiver, freezes (number appears on screen), then resets, then slow on channel changing. OK when ch chaninging on EPG.
anyone else same probem. Should I reload ?
Username: Nydas
Post Number: 6727
For Pansat 2500/FLU new conversions and converted to 2700
Use only on converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
In case you have difficulty getting the latest BIN, it is available here.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest jvvh_235 files for Pansat or Fortec remote
The latest CS_233T_lightning Bin included
These three files are also available separately for those who do not want to download the full kit
http://public.box.net/2500_full_kit
FOR FIX dated 3rd January, 2008.
Leesburg, Georgia
Post Number: 703
Nice job, Nalin. That's real community service.
Username: Jkmago
Post Number: 137
So far so Good no problem, everything working fine.
Username: Aryan
Mississauga, Ontario Canada
Post Number: 34
if it gives scrambled channels, press "SIG" (signal) button on remote twice and channels will come.
it worked for me i dont know how, but....worked.
Username: Aryan
Post Number: 35
Nalin thank you so much.....
(others should also say the same to him/any one who is posting real helpful posts)
Username: Vic123
TorontoCanada
Post Number: 45
hey guys wat loader should i use to load the bin to my 2500 to 2700
Username: Angelquin
Jogi Mago
Files at
Thanks for the link. Easy and fast.
Username: Hicham
Post Number: 101
thankxxxxxxxx Nalin Nyda for your help cause all web sites are busy.
canadiens 5- tampa bay 3
go habs go
happy new year to all,
Username: Vic123
TorontoCanada
Post Number: 46
can any1 help me?
Username: Nydas
Post Number: 6759
Use BL Updater 1.4 for all Pansat 2500-2700 conversions.
Username: Vic123
TorontoCanada
Post Number: 47
Nalin Nyda
thanks for your help :-)
Username: Jkmago
Post Number: 140
Please share your experiance about downloading CS235 lightning file from www.satnow.info.
Hope everyone found the site good. Easy and fast and never busy as others show at the time of Bin release. File is always loaded there after testing so no need to worry.
Cheers!
Username: Machedonul
Post Number: 299
i downloaded both 235 bins for a converted 2500 to 2700...does anyone of them have a GC fix?
or are they identical
Username: Nydas
Post Number: 6806
They are identical functionally - If the BL 235 BIN for the real 2700 gives you GC, then these will.
Post Number: 300
thank you nalin, i come on this site daily and i see that you give a lot of good advice
thanks again!!!
Username: Letmeon
Post Number: 173
had the power up problem w/ CS_235T bin.
Tried the JVVH version of 235 bin
(Jvvh_PansatRemote_235.bin)
Have Panterc Ultra MX (2500 converted 2700).
Username: Letmeon
Post Number: 174
NO POWER UP problems.........
Username: Maldito
Post Number: 19
Thanks Nalin .. as always you rock!
Upmanis ... so you advice to use the Jwh bin?
Username: Undisputed
Post Number: 19
"scrambled or bad channell" tried evetything above didnt work. what should i do?
Post Number: 20
system information is { safe:75-235T_EUbX Boot ver:75 }. Anything wrong with that?
Post Number: 21
Help please.
Username: Nydas
Post Number: 6841
Some people are saying that jvvh_235 BIN works better. Selection is based on the remote you have.
Available from:
[link removed]
Username: Jagr1234
Post Number: 142
Vince did you set the default keys and let it roll. i had to do that twice before this bin worked. Odd but true...never had to that before.
Username: Nydas
Post Number: 6844
I am testing CS_235t_lightning myself and it works almost too good to be true.
Username: Nydas
Post Number: 6853
Vince: As a last resort, somebody else with persistent problems open the box, unplugged th e power from motherboard, plugged it back in, and started all over again with excellent results.
Post Number: 22
dickfoil, let it roll!! I am supposed to turn the autoroll off or am I missing something here?
Username: Jagr1234
Post Number: 144
turn off autoroll and reset default key, let it roll.....that should work,
still autorolls with selection set to off
Username: Hangon
I am getting no signal. Everything was working great last night. Now I am getting Level 31% and Quality 0% on birds 110 and 119. 235t bin used, whats up?
Username: Nydas
Post Number: 6860
Pansat 2700 and clones and Pansat 2500 to 2700 conversions.
Initially, Autoroll is kept on, to let it roll. Then keep it off for reducing freezes. New keys will come in anyway even if it is off, e.g. DN key 00 changed a few minutes ago and roll in even though the autoroll was off in the converted BIN.
Username: Vic123
TorontoCanada
Post Number: 49
wow works better then my viewsat
Thanks Nalin Nyda respect
Username: Nydas
Post Number: 6861
The Pansat haters do not realise that right now the converted 2500 works better than all the Viewsats and even better than the Sonicview 4000 which I have in front of me for comparisons.
Username: Hangon
Post Number: 7
What happened to the file? I had to reload the CS-235t in my convert 2500a 2700 and now I get every channel back. I had no signal before. I guess it had something to do with the Diseqc switching? I have the 2500A since they first came out and still today works, I am not ready to jump ship. If I jump ship is the Viewsat a better box?
Username: Nydas
Post Number: 6867
I think with the current problems at the support site, you are better off with a Sonicview 4000 (about $185) or Nfusion (about $220)
Username: Snw7619
Bahamas
Post Number: 143
[link removed]
Username: Omar_nab
Post Number: 31
whuch bin is better for pansat 2500 converted to 2700 jvvh_235 BIN or CS_235t_lightnin ????
Username: Tito71
Post Number: 20
Nalin
Would you please explain to me in full details how to use the channel master as every time i download an new bin I have to scan all files again and sort them in my favorites . Thanks for your kind help.
Username: Letmeon
Post Number: 177
jwh_235 bin for me.
have Pantec Ultra MX.
no problems with it
Username: Dunamiskid
Can some one post the sip file for the FLU bin? All the sites I have tried doesn't seem to work for me. I am a newbiw an a sure need help
Username: Nydas
Post Number: 6919
John Cox: What is a "sip file" - What are you looking for?
Username: Joe_sceptical
New York United States
Post Number: 9
I have mixed results with the CS_235T_Lightning_100t_Series_serial.bin on a converted FLU. I have no problem getting the channels I want, but EVERY time I turn the unit on, it reboots. Hangs on the number 2 a while then goes through its regular b75 thing pausing on the number 5 for a while, then it comes on. Any ideas?
Username: Nydas
Post Number: 6943
There is a revised CS_235v1_lightning available in the last 3 hours. It is said to fix the glitches with the original CS_235t_lightning.
[link removed]
