Help with vs ultra
Username: Raby
Detroit, Mi Usa
Post Number: 14
hi
i was trying to download the new bin for my vs ultra
and my son turn the power off before reboot and i turn it on again but i lost every thing and i didn,t know how to bring it back
can some body help me please
Username: Saqeeb9000
Post Number: 1379
so is it still working for you...
like can u turn it on...
Username: Raby
Detroit, Mi Usa
Post Number: 15
thank u for ur answer but it,s not work
its give me weak or no signal
Username: Raby
Detroit, Mi Usa
Post Number: 16
and the receiver screen give me ----
Username: Moneyguy
I too am having problems with my VS Ultra. I lost all the channels when I put th new file. I tried scanning a blind scan and a satelite scan, nothing....any suggestions...
Username: Amt
Post Number: 59
i upgraded to the new bin that came on 5th as PFTAUSW-080104U-1.PGM and had same problem all you need to do to fix it is use a loader and put the factory bin by null cable and then ugrade it back to the lastes bin it will work .
Username: Moneyguy
Thanks AMT...can you tell me exactly how I do that. I have never done. Thanks.
