Nfusion ipvr
Username: Saqeeb9000
Post Number: 1230
its recording on my computer.........but i can not play the file.......
what's a reason........
Username: Adave
Post Number: 95
try to play with vlc player
Username: Yakovaki
Post Number: 152
you must stop it to watch...if you did that im sorry for sayin it :p
but its in mpeg format uncompressed
it played fine on windows media player (11 i think)
if doesnt work for you try google search for media player classic (this thing plays everything)
Username: Yakovaki
Post Number: 154
yes dave...vlc is also a great selection
Username: Ke5aqn
Post Number: 2821
Sada,
What is the file extension of the video file
re: .wmp .mpeg .txt .html the stuff at the end of the file name is the extension
So I can go see what all players will play it..
Post Number: 1232
one more question..
on my rec...
dchppp/static.. when i am recording does it need to be static or dchp
ip adress,, 192....................
subnet mask 255....................
gateway.192............
pvr serv. ip adresss........its different too...
isn't it should be same as ipadress.
and i will try vlc and post results..
Post Number: 1233
mpeg...........
Username: Adave
Post Number: 96
Sada i don't like iprv it's lots of problem. i jsut buy dvd recorder.
Username: Vndpatel
Post Number: 429
sada your suppose to have it on DCHP
Username: Yakovaki
Post Number: 156
sada....the box has an ip like 192.168.0.100
and the pvr (your computer) has an ip like 192.168.0.101...102....103...etc....
best to do is make it static on both so that they never change
pvr server will have different ip
Post Number: 1234
thanks guys vlc is playing the video...but its not clear........
Post Number: 1235
dvd recorder option............which one is good one..that works good with nfusion...
Username: Yakovaki
Post Number: 157
all will work
its video in so you output say from svideo or component and record straight
as far as clarity...mine showed exactly as on tv perfectly
i dont know why you are having so much trouble with it?
i am very happy with pvr
my internet is fast and maybe it may help a little since i have 18 megabit maybe try a hub
