UNDERSTAND BEV
Username: Solano2008
Toronto, Ontario Canada
Post Number: 24
FTA TESTER NOW PLEASE EXPLAIN WHAT IS BEV. ALSO I HAVE FLU CONVERTED TO 2700 I ENTERED 232T DIDN'T GET CHANNELS THEN I RESET MY RECEIVER TO FACTORY SETTINGS AND THEN RE-LOADED THE 232 LEAF BIN NOW I AM NOT GETTING ANY CHANNEL. NEED SOME EXPERT HELP.
THANKS,
Username: Satgrl
Post Number: 1202
bev meaning beverly is channels from canada..usually 82west 91 nimiq 1 and 2....if u did facotory settings u loose channels..so u must re scan ur satellite just go to menu and do a bind scan..hope this helps..
Username: Ke5aqn
Post Number: 2479
BEV= bell express View....a canadain satellite provider owned by echostar like Dish Network that transmits via 91 and 81...
whats your set up?
what lnb's, switches, everthing
Username: Carpie
Post Number: 12
And I thought beverly was my aunt from Toledo!
