Nalin and People with experience Help Me!!!
Username: Cricket674
Post Number: 164
The problem is the same... The satellite says scrambled or bad channel every now and then... I see many new bins but which bin is right for Me??? can you post the exact link... I have a converted Pansat 2700a. Please tell me the exact bin that i should load..
These are my settings
Clonesafe: 75-231T-EUbX
Boot Version:75
22 december 2007
Nalin Thank You Very Much for helping me all the time and sorry to disturb you...
Post Number: 166
anybody there to help me???
Username: Thakkar2000
Post Number: 149
if u have converted a fortec to 2700 then use JVVH 232
go to dssworld*co*nr
(instead of star ad a dot . )
Post Number: 170
I didn't convert a fortec... Which bin should I use now???
Username: Viruscauser
Leesburg, Georgia
Post Number: 641
The same one - jvvh_232 bin for any converted 2500>2700.
Username: Asharfi
Post Number: 1634
Bobby ... load bin Jvvh 232 and you'll be fine
Username: Asharfi
Post Number: 1635
Bobby ...
you HAVE to convert your fortec to a pansat 2700
Leesburg, Georgia
Post Number: 643
AV, you misunderstand. He already has a converted 2500>2700, just not a Fortec 2500>2700. He thinks he needs a different bin if it was not a Fortec that he converted.
Username: Nydas
Post Number: 6492
Once a Pansat 2500A, Pansat 2500 clone, FLU, Pantec, Megasat - any one of them is converted with B75 Boot and a jvvh Bin 208 upwards, you can use any of th elater conversion BINs. The conversion BINs are NOT specific for any receiver you originally started with and are interchangeable.
Username: Jamie1937
I have a viewsat extreme. I downloaded latest bin and tried to open it. It says it cannot open because it needs to know what program created it . Can you give me any ideas how to open it? Thanks!
Username: Dimwitt
Post Number: 320
you don't open it.
use loader2 to select the bin , then transfer pc to stb
Post Number: 171
Thank You ... I know I am a bit annoying but I am learning because of all you you people that are experts at this.... Thank You very much I appreciate it... One more question I loaded
CS_232T_Lightning_100t_Series_serial into my converted Pansat 2700 (2500/2700) not a fortec!!! It is working amazingly now it has said Scrambled or bad channel only 2 times in 2 days... but just to make sure... should I load the jvvh bin or should I stick with this
Username: Nydas
Post Number: 6519
All 5 232 conversion BINs work the same.
Username: Thrill_nyda
AKA PULP FICTION
Post Number: 20
My Muslim brother Nalin speaks truth!
Username: Nydas
Post Number: 6526
I am neither a Muslim nor your brother.
