Jvvh 232 - FREEZING FIX
Username: Asharfi
Post Number: 1632
Here's the file for the converted FLU/Pansat 2500 - Pansat 2700 receivers which fixes the freezing issues. Download from dssworld
Gonna post more files in few minutes ...
Username: Vick0901
Post Number: 23
Hey AV, is the file called jvvh_leafs(BG)232? Should I load that file onto my converted 2500-2700? Also, is there a fix for the viewsat xtreme 2000 box?
Username: Kirankumar
NC
Post Number: 374
good job again AV
Username: Nydas
Post Number: 6468
For Pansat 2500/FLU new conversions and converted to 2700
In case you have difficulty getting the latest BIN, it is available here.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest jvvh_232_(BG)_ bins included and available separately
The latest CS_232T_lightning Bin included and available separately.
http://public.box.net/2500_full_kit
FOR DN and BEV FIX 24th December, 2007.
Username: Asharfi
Post Number: 1633
FD,
Yes, you can load this JVVH 232 bin onto your converted receiver. Sorry, no freezing fixes for Viewsats.
African,
Thanks, buddy!
NC
Post Number: 375
AV,
please post when freeze fix is out for c00lsat 7000.thanks
Username: Hoosier_daddy
Post Number: 143
anyy ppv on this one
Username: Domy
Post Number: 72
I load bin 232 doesnt work
the key is the new key
only says waiting picture
Username: Aine
bin 232 for flu 2500/2700 not work for BEV enter manually keys but bug scrambled or bad channel is fixed
Username: Domy
Post Number: 73
i did entry manually but doesnt work for BEV
do i go back to 231??
Username: Aine
is work great for me :
new keys for BEV :
B3V 0901 - Last Update: 12/24/07 09:07 AM
00: 10 8D 49 91 EE 05 AC 17 67 BE 3D 23 31 B5 0A 01
01: 5A 3E 91 5B 6B 94 5A 5E 6C EF 60 86 DA 6C 23 B2
Username: Dishlover
Toronto, Ontario Canad
Post Number: 79
Hi Nalyn, does this CS232T Lightning fixes the freezing problem for DN. Can you please confirm this.It is available on below link.
[link removed]
Username: Nydas
Post Number: 6484
I have used the CS_232 and the jvvh_leafs_232 on a converted receiver and it works extremely well with all premium, Internationals and P0RN channels on DN. I am waiting for reports on BEV.
Bev Key 00 for ID 0901 changed today and is as posted above. It should autoroll and should also work on manual input followed by switch off at back and on.
Username: Lucia
Calgary, AB
Post Number: 434
what theres new bin? :|
Username: Nydas
Post Number: 6486
Lucis:
Username: Lucia
Calgary, AB
Post Number: 436
got it thank you nalin.
Username: Bomberman
Post Number: 94
people, load the new cs_232t bin instead
Username: Johndoe1776
Merry Christmas Everyone.
I will give your file a try Tamara.
Thanks for the present.
Username: Tscon
Post Number: 77
"people, load the new cs_232t bin instead"
Using CS_232T on DN BOX gets frozen displaying # 5 , then it has to be rebooted
manually using button on the back of the BOX.
Also Every 2-3-10 min "Bad or Scrambled Channel"
Box is pumping up, which disappears after 1 min or so, which is pain in the A.., cause you like watching 2 min and waiting 1 min, it's of course better than nothing, but this bin S*CKS!
Username: Tscon
Post Number: 78
Using JVVH_232 box getting self rebooting?
Is this JVVH_232 better than CS_232T ?
Thanks
Username: Jkmago
Post Number: 105
using jvvh232 since 24 Dec, 2007 morning and everything working great for D/N.
Username: Tscon
Post Number: 79
RE: "using jvvh232"
Could you please provide link where can I download that file? Thank you
Username: Tscon
Post Number: 80
ohh, sorry ;) Got it, thanks
Username: Tilu
Toronto, On Canada
Vasil
Please post the link for jvvh232 please
Username: Tilu
Toronto, On Canada
Nalin
I am not able to get jvvh 232 from the following link public.box.net/2500_full_kit.Could you please provide any other link.
Thank you in advance
Username: Tilu
Toronto, On Canada
Nalin
I am not able to get jvvh 232 from the following link "public.box.net/2500_full_kit".Could you please provide any other link.
Username: Asharfi
Post Number: 1640
tilu,
Download from www.dssworl*d.co.nr (remove * from the link)
Username: Tilu
Toronto, On Canada
thanks AV
Username: India101
Post Number: 26
i want to know how do enter the bev keys. when it says 86 does that mean 00 and 96 means 01 or they are all 00.
also what is the latest keys for bev could please post them hear is the latest one that i put
96: CD 13 C6 F3 0E C6 F8 E3 2E D8 4C 8D 5B F6 B0 E5 New
is this the right one because when i put them it showing picture downloading when i put 00 with this keys and scramble with 01.
nalin or any one please help
Username: Sachyadeewana
get all your latest keys from [link removed]
BEV and DN updated their keys yesterday. enter them manually first, and make sure Autroll is turned ON. Sit back and njoy both BEV and DN ...plus no freeze issues whatsoever with the new 232T bin.
Username: Solano2008
Toronto, Ontario Canada
Post Number: 22
downloaded 232 leaf on converted FLU but still getting no signal message.
Need help keys alrady changed to the new ones which are posted here
This bin works with the FLU!
[link removed]
Merry Christmas to Everyone
Username: Dishlover
Post Number: 82
John Doe thanks for copy paste of my link posted above.
