Dish Network Not WORKING!
Username: Nusrat
Post Number: 14
Dishnetwork on Echo3 isn't working on my viewsat ultra. is there a new bin file or key i need to key in to make it work??
Username: Space_invader
Andromeda M31
Post Number: 344
well... if it is not working with the new bin, you should wait... in the mean time check the switches & satellite settings... check the cable, other transpoders, etc...
Username: Dude123
Post Number: 1672
Dish net is workin file, I am watching it right now....there was a key change this evening make sure your autoroll is on so it can roll the keys in. Do a hard reboot from the back switch aswell.
Username: Monchito911
Post Number: 21
how doet the boot in ultra?
Username: The_devil
Post Number: 85
same here myne has been scrambled to should i insert the key manually i have CW600p
Username: Dude123
Post Number: 1674
flip ON/OFF switch on the back of the box if thats doesn't work then enter keys manually.
Username: The_devil
Post Number: 87
I turned of the reciver and manuallay put the keys in but still no Dish. can any1 tell me the new Keys. So i can make sure im putting the right one in
Username: Greatful
Post Number: 78
i think we are down i don't get any channels
Username: Ke5aqn
Post Number: 2331
Jack is Echo3 the only sat that you are not getting? Do you receive other DN sats? Are they scrambled as well?
Username: The_devil
Post Number: 88
i have Echo 3 and 7 both of them scrambled
and when i enter the new key it changes to something else
Username: The_devil
Post Number: 89
Ok i got it to work by loading 1.64
Username: Asharfi
Post Number: 1636
spartan,
Please make sure that you have the latest bin. If yes, then please try to enter the latest Dishnetwork keys manually.
Username: Dharm_ram
Post Number: 78
i m also not getting anything on DN ...its completely down
Username: Asharfi
Post Number: 1639
dharm,
Receiver name?
Username: Dharm_ram
Post Number: 82
vs ultra
Username: Ke5aqn
Post Number: 2338
Dharm pick a thread and ONLY ask questions in that thread. AV is helping you here. stay here. I will not help you now in the other thread.
Username: Dharm_ram
Post Number: 85
well..AV didn't answer me..that's I put my problem in another thread too
Username: Ke5aqn
Post Number: 2340
ok so i will help you here.
list your set up
receiver, switch, lnb, antenna? everthing
Username: Dharm_ram
Post Number: 88
Viewsat ultra
sat - echostar 7
LNB - STANDARD
LNB FRE - 10750
TP FREQ - 12224
DISEqC 1.0 - None
Username: Ke5aqn
Post Number: 2342
ok that is youtr receiver and some antenna settings you listed
what is the actual lnb you use? how many? 1 or 2 or 14 antenna's?
Do you use a switch?
Username: Dharm_ram
Post Number: 89
well..something technical and new for me..may be i m wrong...
1-LNB
1-ANTENNA
and guess.. no switch
Username: Dharm_ram
Post Number: 90
are these signals fine?
Username: Ke5aqn
Post Number: 2345
Well no
You have no qualty! what satellite is the antenna pointed to in the sky?
Username: Dharm_ram
Post Number: 91
again technical? only thing i know is i didn't change any direction of antenna..and my 100% doubt is that due to heavy wind direction is changed...
do u recommend changing my direction and then give a try?
Username: Merk
Post Number: 28
mine is working with this for e7
lnb freq 11250
tp freq 12239
Username: Ke5aqn
Post Number: 2347
Change lnb frequency to 11250 and lets see if you can get quality..
Username: Jdq
Post Number: 179
yes put frequency to 11250 and move to transponder 12239 like mjhp said
Username: Dharm_ram
Post Number: 92
already tried..nothing works...
Username: Ke5aqn
Post Number: 2348
12224 is a active transponder. I get 100% sig and 100% quality on it.
Username: Tytaz
Post Number: 30
You also have no signal. You need to move your dish till you see echo 7 beside antenna setting .(Right beside it)
Username: Tytaz
Post Number: 31
beside antenna setup ...sorry
Username: Ke5aqn
Post Number: 2349
so you put the lnb back to the correct 11250?
put it on that and keep it on that. no other setting in that feild will work.
If you do and still have no quality you need to make sure you antenna is pointed correctly....
www.dishpointer.com is great to help with dish pointing it shows all the tilt settings and directions. Just go thier, change fields to represent your location, and the sat your pointing to..
Username: Dharm_ram
Post Number: 93
thanks a lot..will try that...i already had a doubt that my antenna was pointing to wrong direction...
Username: Merk
Post Number: 29
there is a bit on tp's here for you all
https://www.ecoustics.com/electronics/forum/home-video/422512.html
Username: Snissar
Post Number: 22
there was key change for DN recently
Username: Tytaz
Post Number: 32
dharm do what Tester suggested first before moving your dish...
Username: Ghostcdn
Pescara, Abruzzo Italia
Post Number: 15
12224 not for 119
Username: Dharm_ram
Post Number: 94
its all here..nothing as such special
Username: Tytaz
Post Number: 33
Dish
------------01 01 00------------
35 1B AA BB BF E6 CB 3E
5C AF B8 4D F0 59 45 B8
9D 70 7B 49 88 DC 0B 67
E4 D2 EB EC 76 D2 1B 17
Username: Dharm_ram
Post Number: 95
stev ..what is this what i have to do??
Username: Tytaz
Post Number: 34
once you setup everything correctly and get a signal. You then need to change key codes for DN....Tester can probably explain it better I think.
Username: Ghostcdn
Post Number: 16
set up like this:
sat - echostar 7
LNB - STANDARD
LNB FRE - 11250
TP FREQ - 12239
then put it on channel 200 let it roll
Username: Ke5aqn
Post Number: 2351
did you try that transponder 12239 for 119 echostar 7?
That transponder is active as well as 12224
set the antenna settings at
echostar 7
lnb power on
lnb type standard
lnb high 11250
lnb low 9750
tp frequency 12224
diseqc off
motor off
legany SW none
Make sure all connections are tight
if still no quality
go to www.dishpointer.com
adjust all fields to your location and that sat
and read the sugested direction and tilt settings then cheak to see if antenna matches
Username: Farina
Post Number: 12
I think the new bin did something to ultra.
Since I downloaded new bin, no signal, no quality.
May be it killed the ultra.
I was getting signal on extreme, but when I downloaded file the signal and quality on it was also lost.
