Sonicview 1000 problem, any advice ?
Username: Rufa33
Post Number: 218
The latest bin 182 freeze fix, killed my sonicview. It shows like half 0000 with dashes on second half of zeroes. It happens as the bin got fully loaded and shows on screen flash rom updating, then restart .. dead.
Anybody have any idea how to fix it. I can't load anything and sometimes when I restart the stb shows me less than 0000 on the lcd.
Username: Rufa33
Post Number: 219
Anybody here got some suggestions ?
Username: Yakovaki
Post Number: 106
try reloading the bin after loading a factory file 1st
Username: Yakovaki
Post Number: 107
get the bin from totalfta.com only though
get the factory file from another site that has it posted such as ftatalk or just about any other site will have a factory file
or even get directly from sonicview website
Username: Rufa33
Post Number: 220
I tried, I can't load anything. It's just get stuck at start with the 0000, that is not real 0 but more or less a mix.
Username: Yakovaki
Post Number: 111
hmmm
are you sure u dont have a clone?
where did you get the file from?
does the file have a release not with it that was modified on dec 22???
Username: Yakovaki
Post Number: 112
try turning the box off from the back and on....wait a lil bit see if it gives some sort of picture on the tv
if not then do the following:
get the loader and factory bin....go to your computer and flash it using the serial cable to the box
then get the ultra file from ftatalk.com and load it on the box using the usb
good luck
Username: Yakovaki
Post Number: 113
o wait u have sonic view sorry forgot
ok yes go to totalfta.com get hte latest bin
load it same way as u normally do...if it does not work then you must load the factory bin that you can get
using the serial cable of course
Username: Yakovaki
Post Number: 114
cant find factory flash?
go to sonicviewusa.com
click on support
find your model numbers firmware file (factory flash)
load with serial cable
should take care of it
let me know how it goes i will be here for 20 more mins
Username: Ke5aqn
Post Number: 2129
JB is right. Go get your factory bin, upload that to the receiver, then upload the newest bin. I have had several Viewsats do the same thing and that is how we fix them.....I will here on and off all weekend if you have any questions..
Username: Rufa33
Post Number: 221
I did all that steps, this is the first time I got trouble with Sonicview, I did load the latest firmware 282p that fix the update freeze. Was working fine on 281p. Everything was normal just when restart .. things went really bad.
Username: Yakovaki
Post Number: 115
hmmm
no fta i made a mistake was helpin someone with ultra at same time
he has sonicview
ok so you did what??
loaded 282p?? where did you get it from? get a fresh version from totalfta.com
do this.... load the factory file from sonicviewusa.com
then load it again.....
then load 281p see if that works since you said it did
after that....load factory file again
then load 282p
im sure it will work
let us know danny
Username: Rufa33
Post Number: 222
It does not communicate neither shows anything on TV. No reaction to the remote at all. Turn from back on and off and still shows 0000 with half dashes between and to the lower line. I did try to do the cools*t reload the firmware and seems it's not working, I know I need to be in a good timing to load the factory file at start but it didn't change the 0000 and shows there is no connection.
Username: Yakovaki
Post Number: 116
ok make sure the cables are tight on both ends (serial cable)
try again to load the factory file
tell me what it shows and says on the display after
remeber to load it 2x in a row
Username: Rufa33
Post Number: 223
JB thanks for helping. As I told you it's weird. There is no communication with the stb. The loader I'm using is the latest and doesn't show if there is serial connection or not. So you are blind loading the file, if it works and it did work all the times before. Now there is no reaction from the STB. Sometimes if I restart from back over two or three times in row, it shows nothing .. like dead LCD, Black.
Username: Rufa33
Post Number: 224
I can't load the factory firmware if there is no communication. The cables are fine, I got my old Lifetime from closet and it did work fine with loading. So it should be the Sonicview is the trouble. This device worked like a charm never ever got an issue with before. Now seems like is not even reaction to the pc connection.
Username: Yakovaki
Post Number: 117
oohhh so you are having a problem with the loader
hmm download a fresh copy of the loader from sonicviewusa.com
try changin the serial ports from 1...to 2...etc... and load the factory file
tell me how it goes
Username: Rufa33
Post Number: 226
No difference, I don't think it's the loader neither the connection. It's from the device itself. It does not communicate. The software is the latest I think version 0201. I do have the factory bin too. But I don't see any results from doing that.
Username: Yakovaki
Post Number: 119
hmmm
ya the box may have been screwedd by bin????
ok well try leaving it unplugged for 15 mins or so and try loading factory again....if not than i dunno maybe u have to send to sonicview n tell em off or something to get a new one
Username: Rufa33
Post Number: 227
I have already contacted them, waiting for RMA. Thanks for your inputs.
Username: Yakovaki
Post Number: 120
any time danny
good luck with all and have a great holiday
