Full_kit and CS_229T_lightning
Username: Nydas
Post Number: 5995
In case you have difficulty getting th elatest Chancy BIN, it is available here.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included. The latest Chancy CS_229T_lightning included separately.
http://public.box.net/2500_full_kit
FOR BEV FIX ONLY. NOT GOOD FOR DN NOW
Username: Domy
Post Number: 9
Nalin they said bev is down now is this bin can work???
Username: Ustaad_hc
Post Number: 455
no
Username: Dharm_ram
Ok..am new to this...Nalin, can you explain me what exactly is this or put some link where I can learn more
Username: Jkmago
Post Number: 65
Can you confirm that this is tested and good to install on 2700 clone?
Thanks
Username: Nydas
Post Number: 5997
The latest Chancy CS_229T_lightning included separately. FOR BEV FIX ONLY.
This BIN is 2 hours old. If thing have changed in the meantime, obviously this BIN cannot accommodate the change.
If you download the package and/or the file, it will not burn you!!!
Username: Nydas
Post Number: 5998
Jogi Mago: As I said very clearly. It is for 2500/Flu converted to 2700. It is NOT intneded for 2700 or 2700 clones.
Username: Zuhere79
there is complaints on ftabins.com (fortec disscussions), that their recievers were burnt from this bin !!!
Username: Jkmago
Post Number: 67
Ok, is it only for BEV or for DN also?
or do we need CS230 for DN?
Username: Laurad
Post Number: 61
Hi Nalin Nyda, just a quick question. Do you know how the BIN by Chancy will be numbered for DN since CS-229T-Lightning is for BEV only. Will he use the same BIN number or will it change for DN users. Thanks LauraD
Username: Nydas
Post Number: 6001
Chancy's BINs are numbered by BL not by Chancy.
When BL comes out with the next BIN and calls it 232, Chancy will call his BIN CS_232T........
I thought it was pretty obvious.
Username: Nydas
Post Number: 6002
BEV New PID - 0907 {Last update: Sat. Dec 15, 8:21 PM EST]
Key 00 (86) :
DD 13 CA 6C 03 81 99 ED E2 A6 0F 8D A5 B7 7A 5F
Key 01 (96):
60 B8 E2 A1 25 9F 09 6F FB 9B 30 FF 61 95 EE 65
The latest key 01 of new PID 0907 has changed and is the cause of new BEV ECM. Note the date/time stamp of the ECM
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 228
VS is down on bev as of 20 mins ago...loaded the new CS_229T and am down also...I think this bin is already invalid....new ecm for bev...now looking at 230 bin...ps...NN...could not find bin on your box...moot now
Username: Kacha
Post Number: 36
is there a new DN bin for 2700flu??
Username: Nydas
Post Number: 6005
No......NO.......No.......NO.......
Username: Kacha
Post Number: 37
okayyyyy
Post Number: 231
sorry NN...did not mean to duplicate your post...I was testing as u were writing and just wrote without looking
Post Number: 235
King Tapeman confirms Bev is working on older VS bin...wonder if the same holds true for older conv bin?
