Echo 110?
Username: P0tzzz
Hi, my echo 110 has no signal(119 is fine), I was wondering if anyone can help. Did it move, if so, which way did it go(LOL, I always wanted to say that) or does anyone have a link to an old thread with the answer? Any help is appreciated...
Username: Rtap
FL
Post Number: 1446
dee need more info.your setup???
Username: P0tzzz
sorry...I have a pansat 2700a with DN...my problem is actually that I'm missing alot of the movie channels that I had before(ie. channels 503-530. I used channel master with a channel list that I downloaded from another site and I did a blind scan, but I'm still missing those channels for some reason. Please help...
Username: Rtap
FL
Post Number: 1451
what bin file are u using
Username: P0tzzz
bin 228...I'm able to watch everything else so the bin seems to be ok.
Username: Team_blacklist
HEADQUATERSPIRATE
Post Number: 16
dee do a tp scan for those missing channels. check your settings in antenna setup to make sure they are ok before the scan.
Username: P0tzzz
I just did a tp scan but still the same...maybe I'm doing something wrong or something. I currently have only 2 movie channels(502 and 505), but I have all of the other channels though(ie. hbo, sho, max, por*n...etc). Maybe I just need a new channel list or something. Anyway, I just wanna thank your guys for helping.
Thanks,
Dee
Username: Rtap
FL
Post Number: 1455
tell me your settings in antenna setup .
Username: P0tzzz
Post Number: 7
lnb type - standard
lnb local-freq. - 11250
22khz - off
diseqc - off
legacy sw - none
skew - 45
tp - [6]12265 h 20.000
positioner setting - disable
satellite scan - all
level = 80%
quality = 90 %
(not sure if this is what u mean)
Username: P0tzzz
Post Number: 8
the setting above is for echo 110
Username: Psychmonster
Chi town, Il USA
Post Number: 196
if you are using dn as your channels, disapearing premiums are the first sign of impending ecm or morph...it now begins for real...DN is going down
Username: Rtap
FL
Post Number: 1457
dee psyc might be right.if you notice channels missing charlie might be working overtime
Username: P0tzzz
Post Number: 9
that sux donkey ballzzz...thats for the help though
Dee
Username: Rtap
FL
Post Number: 1459
don't you meanUpload
Username: P0tzzz
Post Number: 10
LOL, or these...Upload
Username: One_eye_jack
Post Number: 110
Dee
You are not telling us the truth or you are not reading it right, there is no Freg.12265 listed for Echo 10 or 8.In order for someone here to help
you they will need you to post the right info.
Username: P0tzzz
Post Number: 11
Yukon, this is what I see when go to antenna setup. I'm not an expert so please explain what I'm doing wrong, thanks.
Chi town, Il USA
Post Number: 200
forget about it..she should be getting a sig for 110...but its moot...its all over for now
Username: P0tzzz
Post Number: 12
ok, this is weird, I just went back into setup and the tp has changed since the last time I checked.
It's now:
tp - [36]12513 V 20.000
Is this normal?
Username: Joeturn
Post Number: 100
just blind scan your transponders have changed Try 10750 if that does'nt load the horrizontals!
Survivor is on cable brb
Username: Razzorwyre
Post Number: 64
Doesnt sound like an ECM if the entire sat is missing. Plus 119 would also go black. Sounds like its a settings issue with your 110 lnb.
All up on DN here 110/119 prems,ppv and P0rn.
Post Number: 65
One more thing, is the signal dropped? or is it autorolling. If dropped check the lnb and settings, if autoroll then ECM could be issue but from the inital post says sat with no signal.
Username: Nydas
Post Number: 5894
1. Disconnect the software setting of diseqc from 1 to none and save.
2. Switch off at back.
3. Connect 110W to DisEqC port 2 in software.
4. Blind (power) scan.
Use your judgement and common sense after that (regarding connecting 119 again) if it works
Username: P0tzzz
Post Number: 13
First of all, I would like to apologize for the title because I "DO" have signal for 110. The reason I thought the 110 signal was lost was because the "movie" channels disappeared(channels 503-530s). I DO have all of the other channels including HBO, SHO, MAX, P0rn, etc...
I have a pansat 2700a/DN. So far, I've tried:
*loading bin 227, then blind scan...no luck
*loading bin 228, then blind scan...no luck
*loading factory bin, then bin 228, then blind scan...no luck
*factory reset, load bin 228, then blind scan...no luck
I REALLY appreciate all the help from you guys(THANK YOU!)
I guess all I can do now is hope they magically come back.
Thanks,
Dee
Username: Saqeeb9000
Post Number: 742
(( throw the crapy reciever and buy something like viewsat ultra .. would be good luck)...
Username: P0tzzz
Post Number: 14
Well, I'm only missing like 20-30 channels. All else is well. I guess I'll have to live with just 1000 channel instead of 1030 channels(estimation).
Post Number: 744
dee i am not sure is there any option on ur crapy (just kidding ) option to do an advance scan where u can mannually add tp's frq, etc.. or did u tried channel master..
Username: P0tzzz
Post Number: 15
Sada, yes I've tried channel master but I am not the one to call myself an expert so I might have done it wrong but wouldn't a blind scan correct that. anyway, fugk it, i guess this crapy(possibly kidding) receiver with 30 less channels then before will have to do for now.
Post Number: 746
Username: P0tzzz
Post Number: 16
I'm at the advance scan option but i don't know what tp/frq to add( did that even make sense, lol)
Username: Joeturn
Post Number: 112
joeturn
Username: Joeturn
Post Number: 100
Posted on Thursday, December 13, 2007 - 08:20 pm:
Just blind scan, your transponders have changed. Try 10750 if that does'nt load the horrizontals!
lets tag TEAM BLACKbetty
Username: Joeturn
Post Number: 113
For not posting his read on Emunation 3.0.0.3
