Receivers working with B3V
Username: Westway11
Post Number: 58
What receivers if any (excluding Nfusion) have a fix for the latest B3V ECM?
Username: Cartier1
Post Number: 1477
why u r excluding nfusion?
Username: Westway11
Post Number: 59
Because I know it works.
Username: Cartier1
Post Number: 1478
jack do u have one ? i heard u have to connect it to the internet . so isn't it risky little .the provider will know the ip adress and u know the rest.
Username: Westway11
Post Number: 60
No I don't have one, and yes, you do have to connect it to the net to receive updates.
Personally I don't think the I.P thing is really an issue, they can get your I.P by downloading normal bin files anyway.
Nfusion updates are hosted on a database, meaning D|SH or B3V would first have to get a warrant to get the I.P's of individuals connecting to the database, same thing for bins. All they would need is a warrant for any popular FTA bin file site and get your I.P. Even after all of that, an I.S.P would still have to be willing to give up the information with who is connecting with these I.Ps. It's really a non-issue for now, unless signal piracy laws change and allow for this to happen, then we're all screwed as far as I'm concerned.
